Greasing front steering & suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigAl2, Nov 22, 2016.
  1. Nov 22, 2016 at 12:44 PM
    BigAl2
    BigAl2 [OP] New Member
    Al
    2007 Toyota Tacoma 4X4 V-6
    None
    My 2007 Tacoma 4X4 has 116,000 miles on it. When I hit a big bump, the front end "sqwawks". The rubber boots on the steering & suspension look like they need grease, but there are no grease zerts. Suggestions?
  2. Nov 22, 2016 at 12:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do you see ripped boots covered in grease or are they dry?
    BigAl2[OP] likes this.
  3. Nov 22, 2016 at 1:28 PM
    Pigpen
    Dan
    Northwest Montana
    That's a good description of the noise. That's the sound of seized lower control arm bushings. There's a thread titled "cam part numbers" or something similar dealing with this issue. You can either deal with it (you won't be able to get a decent alignment if you need one) or open your wallet. It ain't a cheap fix. I had my LCAs cut off and replaced this summer. Only use Toyota hardware, DO NOT use MOOG.
    Steves104x4 likes this.
  4. Nov 22, 2016 at 7:21 PM
    BigAl2
    Al
    None
  5. Nov 22, 2016 at 7:23 PM
    BigAl2
    Al
    None
    Steves104X4: The rubber boots are clean & dry.
