Greasing Sealed U-Joints?
Discussion in 'Technical Chat' started by JMirelez, Nov 14, 2017.
  1. Feb 11, 2024 at 1:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Unless you remove the drive shaft it's just a picture of drive shaft. Once it's out you can move the u joint and actually feel what it's doing if all is good you should feel no resistance if it's dry or just shot you will know. The diff end moves more than the front so you really need the entire drive shaft laying on the floor.
    gearcruncher and DyegoPC23 like this.
  2. Feb 11, 2024 at 2:35 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    OP your truck is nearing 100k. Replace the U joints and carrier bearing (if equipped) as scheduled maintenance items. Then go from there.
  3. Feb 11, 2024 at 2:43 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    My 15 has zerks for every U joint from the factory.
  4. Feb 11, 2024 at 3:54 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    My '11 also has zerks on every joint, however Toyota discontinued the serviceable U-joints years ago and I went with the current part number when replacing mine.
    When I serviced my driveline I first bought the Spicer greaseable U-joints but returned them because the dimension across the caps was too big, no way to get even the thinnest retainer clip in the yoke.
    There should be no issue with the non greaseable joints unless they are improperly installed. The seals are designed to keep contaminants out, versus the greaseable type which are designed to let the old grease and contaminants purge out. The greaseable seals will let water in.
    DyegoPC23 likes this.
