Greasing Slip Joint / Boot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HolyHandGrenade, Jan 3, 2015.
  1. Jul 27, 2019 at 4:57 AM
    #41
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Awesome thread. I’m going to grease mine very soon here. 2008 with 140k on it and my gentle clunk upon takeoff and stop has been driving me nuts and I believe this will remedy it. My truck probably hasn’t ever had that slip yoke greased. I bet it’s bone dry in there. Using motorcraft lube for mine. Recommended specifically for ford trucks. Should be fine. Hahahaha
    lynyrd3 likes this.
  2. Aug 5, 2019 at 1:31 AM
    #42
    TacosNBurritos
    TacosNBurritos Active Member
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    Mobilux EP 2 grease is specifically designed for this application. Read the description from Mobil about this grease. ...for spline shafts...
    https://www.mobil.com/english-ca/grease/pds/glxxmobilux-ep-2-moly
    Just ordered it from Amazon. Started hearing metallic pinging on the drive shaft after performing normal interval greasing of shaft.
  3. Aug 5, 2019 at 6:41 AM
    #43
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
  4. Aug 7, 2020 at 3:25 PM
    #44
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    I never updated the thread.
    This was SUCH an easy fix to such an annoying start/stop clunk. Thanks guys! Super easy job
    hoffengineering likes this.
  5. Jul 25, 2021 at 10:49 AM
    #45
    jgutweiler
    jgutweiler New Member
    2012 TRD 4x4
    I was having the "Tacoma clunk" on my 2012 Tacoma and came here looking for answers. I decided it was either axle wrap, or slip yoke binding at stop. I added leaf spring clamps and that didn't fix it. Next I greased the slip yoke, with some red bearing grease. No dice. I was getting pretty frustrated with it but continued to research it. That's when I saw this comment about Lithium Moly grease.
    I decided I didn't have anything to lose, except for $6 at Autozone.
    I cleaned off all the red grease and added a good coating of Lithium Moly grease. I wasn't too hopeful of this fixing the problem. I mean, grease is grease right?
    Wrong! The Lithium Moly grease fixed it! I am stoked.
    Marc70 likes this.
  6. Jul 28, 2021 at 8:25 AM
    #46
    Steve_P
    TN
    Well, that was a cheap fix- great news. yes, moly grease for high pressure interfaces like this. I researched this online years ago and there are lots of posts from owners who use a Honda grease with high moly content on driveshaft motorcycles. Ideally you want something that lists the moly content as greater than 50% and not just "moly grease" as maybe it just has 5%.
  7. Jul 28, 2021 at 11:33 AM
    #47
    Taylor7787
    Taylor7787 Member
    Taylor
    2009 Tacoma
    is greasing required? these are typically greased for life but are people seeing premature failures?
  8. Jul 28, 2021 at 11:36 AM
    #48
    jgutweiler
    2012 TRD 4x4
    Everything I've read is that over time the slip yoke grease dries out and that's when you get the "clunk". Luckily, it's an easy fix. Drop the back half of the drive shaft, clean the splines of the slip yoke, grease it up with a Lithium Moly grease, and reinstall.
    Marc70 likes this.
  9. Jul 28, 2021 at 11:56 AM
    #49
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Not trying to sound like an ass, but do you think grease will actually make it around the splines if you put a zerk fitting in? I don't.
  10. Apr 19, 2023 at 6:14 AM
    #50
    4Stents
    4Stents Roost or be Roosted
    Appleton Wisconsin
    2013 White Tacoma SR5 , w/peeling paint.
    Frame recall done
    This is a great thread and it got me on a creeper to check , my 4x4 manual Tacoma has only received oil changes at my local Toyota dealer , it has 5 zirks in the driveline and they are all bone dry , so I am assuming it has never been properly greased with a LOF , doesn't the L mean grease.
  11. Apr 19, 2023 at 6:11 PM
    #51
    takefootoff
    takefootoff Well-Known Member
    To summarize this thread a bit,
    Is it confirmed that this service can be done by dropping/splitting the axle at the carrier bearing?
    Lithium Moly grease is the best choice…brand that is available at stores?
    Best way to zip/seal the boot back together?
    Marc70 likes this.
  12. Apr 19, 2023 at 6:53 PM
    #52
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    I have done this by dropping the carrier bearing. The first time I had difficulty getting the axle back together till I forced it in from bottom pushing up.
    The next time was easier as I figured you can play/move the axles around and it went in quite easily from the side pushing inwards. Depends on how your ujoints are lined up. I use the Ford Motorcraft PTFE lubricant.
    Hope this helps someone.
    takefootoff[QUOTED] likes this.
  13. Apr 19, 2023 at 7:21 PM
    #53
    takefootoff
    Much appreciated, so you just gotta rotate/massage the two back together.
    Thankfully I have access to a lift.
    Did you reuse the OE ties on the boot?
    Marc70 likes this.
  14. Apr 19, 2023 at 10:19 PM
    #54
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Moly fortified EP2 greases - in particular the ones that are spec'd to meet the Ford/ Lincoln / Mercury chassis lube requirements - would always be a good choice. Look for it on the label. The spec came out in the 1960's when Ford first started advertising the "50,000 mile undercarriage" and at first you had to get it at a Ford dealer........ Anyway, they priced my dad out of the factory stuff and he started using the Valvoline "Moly-fortified" tubes - I've been using it ever since. It has the Ford spec referenced on the label and even solved some problems on mining machines I serviced - when the ordinarily lithium greases wouldn't hack it.
    takefootoff and Marc70 like this.
  15. May 30, 2023 at 11:28 AM
    #55
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    Today i did the job by dropping the carrier bearing. I have some lift on it so i was able to work under it. The spline was kinda dry. Cleaned everything and i put the same grease i use for the UCA and ball joint. Mobilgrease xhp 462 moly. The blue coating was smooth and didn't saw any missing part or damage. I will add this maintenance item when greasing everthing else. It's something i didn't think off. I know It was done 2 year ago when i bought the truck, every liquid was changed and everything was greased and inspected when i did the refresh on it. I will do it every oil change now.
    Marc70 likes this.
