greasing the front bearings on the taco. Can anyone help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by adiablo420, May 15, 2010.
  1. May 15, 2010 at 10:37 PM
    adiablo420
    adiablo420 [OP] Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    I need to grease my front hub bearing ..got a 96 taco.4x4. 'ike to play in the water so I need to grease the front.. i i have the lock where i have to get out and turn the center of the front wheel dial to go into 4x4.. do i go in from there?
  2. May 16, 2010 at 3:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Aug 21, 2012 at 4:05 PM
    magic
    magic Well-Known Member
    looked threw that url but couldnt find/open anything that was helpful. Is there any articls about gresing front&rear wheel bearings on a 4x4 sr5 99 tacoma?
  4. Aug 21, 2012 at 5:45 PM
    magic
    Sorry im still learning, so i dont ever have to service the front bearings? and how often do the rear's need to be greased?
  5. Aug 22, 2012 at 4:37 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    Was a PreRunner, now it isn't
    I don't think that is what he is asking. Not the bearing itself but the needle bearing in the hub assembly where the axle shaft goes in.
  6. Aug 22, 2012 at 5:39 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
  7. Aug 22, 2012 at 6:27 PM
    magic
    well kinda but all looking to do is grease my bearings because i will be going to school in a month and wont have much access to tools so basically just trying to prevent any bearing failures....
  8. Aug 22, 2012 at 7:37 PM
    Model 70
    Model 70 Well-Known Member
    Central Oklahoma
    97 Tacoma 4X4 Pristine Clean
    JRS leaves, Monroe Redi Struts., Later Taco Mini Header, Alpine Tunes.
    Change the rear differential lube to take care of the rear axle bearings. That is all that you can do unless a bearing actually fails. No way to lube the front units.
  9. Aug 22, 2012 at 10:48 PM
    magic
    so other than changing the diff fluid i dont have to grease the bearings unless they were to fail right? (at that point id need new bearings)
  10. Aug 23, 2012 at 12:03 AM
    n0ms
    Angel
    San Diego
    How many miles on her?
    I have 163k and bearing has never been replaced(from what I know).
    For toyotas if it ain't broken it don't need fixen.
  11. Aug 23, 2012 at 1:02 PM
    magic
    Ive got 169,000 and the gear oil is changed fairly regularly
    ya i hear ya there but i just want to prevent any problems from ariseing due to regular matenience be skipped cause once i leave for school i will only have access to basic tools and would have to do any work in a parking lot
  12. Aug 24, 2012 at 4:51 PM
    hossmaster
    League City, Tx
    I sent you a private message, have you seen it???
  13. Aug 24, 2012 at 4:53 PM
    hossmaster
    League City, Tx
    the 05 and up have a unit bearing. The gen 1 tacos are pressed into the spindle and the manual locked hub assemblies have a needle bearing and two brass bushings that need to be greased. That assembly is pressed into the bearing.
  14. Aug 25, 2012 at 1:20 AM
    magic
    nope i havent got any private messages???
