Great day at the dealership NOT!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kelly6773, Aug 28, 2017.
  1. Aug 28, 2017 at 7:40 PM
    Kelly6773
    Kelly6773 [OP] Well-Known Member
    Bob
    SC
    18 TRD sport DCLB
    The date was actually Friday. I went back and checked. But yes still. Wednesday I believe is the best of any day lol
  2. Aug 28, 2017 at 7:59 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    LOL, some. The ones with families usually are pretty good. The places I've worked at, we'd rotate on half staff alternating Saturdays.
  3. Aug 28, 2017 at 8:07 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Sorry we fucked up your oil change, here is a coupon for some more free oil changes...o_O
  4. Aug 28, 2017 at 8:37 PM
    eurowner
    eurowner Duke Sky
    Scoty
    At my first 6month service, it was written that they put all 4 tires at 36psi. Nope. And the valve caps were missing.
    shakerhood likes this.
  5. Aug 28, 2017 at 8:40 PM
    GPsevinSixx
    Ros Angerus
    What where they inflated to? Sometimes their gauges are off calibration vs. the TPMS by a few PSI. I've had gauges fluctuate from 3~6 PSI and they were either adjusted or returned.
  6. Aug 28, 2017 at 8:44 PM
    eurowner
    eurowner Duke Sky
    Scoty
    In dash was always 35-36. Right after it was serviced it showed 30-31
  7. Aug 28, 2017 at 8:45 PM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Having worked at a Chrysler dealership and trained as a Chrysler certified lube tec. I have seen my share of stuff, the funniest was when a different tec had just dropped and filled a ram with a hemmroid with oil ran it back up to check for leaks and was standing under it when it was started starring up at the engine he figured out in seconds he forgot the oil filter. Blew 4qts of oil in his face.
  8. Aug 28, 2017 at 8:45 PM
    GPsevinSixx
    Ros Angerus
    Sounds about right for the OR trims. My OR states 31 on the sticker.
  9. Aug 28, 2017 at 8:46 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Though the tech wrote in the paperwork it was inflated to 36
  10. Aug 28, 2017 at 8:47 PM
    Kelly6773
    Bob
    SC
    18 TRD sport DCLB
    I took it there with. 31,31,30,29. It was the same when i checked a day later. That's when I figured I check to see what else was done
  11. Aug 28, 2017 at 8:47 PM
    GPsevinSixx
    Ros Angerus
    Then his gauge is definitely off. You can tell the service advisor to let the technician know to not use that gauge, as it makes him look bad. LOL.
  12. Aug 28, 2017 at 8:48 PM
    Kelly6773
    Bob
    SC
    18 TRD sport DCLB
    Mine is sr5. I believe door says 34 I'll double check in the am
  13. Aug 28, 2017 at 8:49 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Hank Williams sang a lesson for all the high-n-mighty TW'ers: "Unless you have made no mistakes in your life, be careful of stones that you throw"
    The Waylon J. version of the H.W. classic:https://m.youtube.com/watch?v=IGCyqk5Afv4
    Dirty Harry and BuddyS like this.
  14. Aug 28, 2017 at 8:50 PM
    ndoldman59
    Murray
    West Fargo, ND
    I had another guy just out of tec school ask witch way the drain plug turned to get it off. And the couldn't find the oil filter, my response on the engine...... Pontiac sunbird back of engine by exhaust manifold.
  15. Aug 28, 2017 at 8:53 PM
    #35
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe the door sticker recommends 30 on the OR if im not mistaken.
  16. Aug 28, 2017 at 8:54 PM
    #36
    GPsevinSixx
    Ros Angerus
    I have a story too. I've left an oil filter off before too in my early days! It was a red 1994 Honda Civic EX coupe. Will never forget that car! I got the name nickname "Exxon valdez " within the first week of working there. LOL.
  17. Aug 28, 2017 at 9:22 PM
    #37
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Mine rolled out at 40psi last time i was serviced....i posted a photo too somewhere in here
    eurowner and shakerhood like this.
  18. Aug 28, 2017 at 9:23 PM
    #38
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    Fantastic! Pics?
  19. Aug 28, 2017 at 9:27 PM
    #39
    GPsevinSixx
    Ros Angerus
    I'm telling you guys, those stick gauges they use are so bad after awhile of service. They get dropped, banged up, and stepped on all the time.
    These are the most commonly used Amflo brand inflator gauges at most dealerships. Never trust theses things.
  20. Aug 28, 2017 at 9:28 PM
    #40
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    I think the procedure to reset the TPMS after rotation requires you to have all the tires set to 30psi. That might explain why they were set to 30.
