GREAT NEWS FOR THROWOUT BEARING / RELEASE BEARING ISSUES!!!! V6 6SPEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigfro, Oct 25, 2010.
  1. Mar 24, 2017 at 9:33 AM
    #141
    bartholomew07
    bartholomew07 Active Member
    Jake
    Colorado
    07 DCSB Sport 4x4 6 spd
    Thanks, don't know how I skipped over that link where you posted it earlier. So sounds like I either go for the $500 "fix" OR I rebuild the slave cylinder. Everyone is so firm on their opinion idk which is better besides the cost factor. :notsure:
  2. Mar 24, 2017 at 9:48 AM
    #142
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Partial "fix" or complete "fix". Whichever your budget allows.
    bartholomew07 likes this.
  3. Mar 24, 2017 at 9:50 AM
    #143
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At the very minimum, do the steel sleeve kit. The aluminum quill will thank you.
  4. Mar 24, 2017 at 9:59 AM
    #144
    hladun
    hladun Well-Known Member
    Alberta
    Tacoma
    Agree. As URD says "Over time as the clutch goes threw it normal wear cycle that air gap between the bearing face and release fingers can get used up and the fingers can start making intermittent contact again with the bearing and can start that squeak again." so their $5OO is the partial fix or do mine which fixes it forever.
  5. Mar 24, 2017 at 10:15 AM
    #145
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You still have angular wear load on the quill. The hydro "Fix-U" alleviates that.
  6. Mar 24, 2017 at 10:31 AM
    #146
    bartholomew07
    Jake
    Colorado
    I'm not confident enough to be working on the tranny myself, I'd have to take it to someone to put in the kit if I went that route.
    The sc rebuild I could definitely do, I've looked at it before when I was trying to diagnose the problem. The hard part looked like getting the hard line on and off w/o bending a king into it
  7. Mar 24, 2017 at 11:59 AM
    #147
    hladun
    Alberta
    Tacoma
    This just never ends. The reason there's wear on the quill is that the TOB flops around because it's unsupported. Preloading it stops the wobble and the wear. The URD TOB doesn't fix it as it has no contact for a while and then as the clutch wears you once again get the low load contact. That's why they have the weasel words in their write up.
    To the objective reader of this forum, this just never stops. Watch this for some humour and to understand what ignoring the obvious looks like
    https://www.youtube.com/watch?v=dhRUe-gz690
  8. Mar 24, 2017 at 12:23 PM
    #148
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What are you talking about? Due to the T56 swap (offered by URD) and the simple operation of the GM TOB, it was obvious to use that style, for URD. The clutch depresses the TOB "near" to full compression. The TOB continually rides the face of the springs. Depressed or not. As the clutch disk wears, and material thickness is lost, and the P.P. springs move over the time of that wear, the spring behind the TOB keeps that continual pressure against the P.P. springs. Thus making it "self adjusting". Eliminating the "low load contact you describe."
    I have the equivalent GM TOB in my T56, in my Tacoma.
  9. Mar 25, 2017 at 7:31 AM
    #149
    hladun
    Alberta
    Tacoma
    Torspd, we both agree (although reading your post it may not sound like it). Once again I quote the URD write up "Over time as the clutch goes threw it normal wear cycle that air gap between the bearing face and release fingers can get used up and the fingers can start making intermittent contact again with the bearing and can start that squeak again." If that's the way they build it then they don't understand how a clutch works. Actually if you think about it, as you say, if at full extension the SC doesn't contact the clutch fingers then how the hell does this work in the first place because the SC is already at full extension? The main reason I object to what URD say is they're reinforcing the erroneous idea that the TOB can't be in continuous contact with the PP. The non-contact BS has been the biggest source of debate on this topic.
    bartholomew07 and Torspd like this.
  10. Mar 26, 2017 at 9:13 AM
    #150
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Subbed. My TOB is wiggling around, 84k miles. On the edge of: just replace everything with the URD fix or deal with it. Sure is pissing me off...
  11. Mar 26, 2017 at 9:23 AM
    #151
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
  12. Mar 26, 2017 at 11:02 AM
    #152
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have seen posts of a few members who have. Either here or on XRU. To tired to look up who they were though.
  13. Jul 10, 2017 at 8:53 PM
    #153
    NOFINISHLINE
    NOFINISHLINE Well-Known Member
    Fort Worth
    2006 SR5
    Tailgate Mod, JBA Long-tube headers, Demello offroad baja front bumper, carrier bearing spacer, Icon Coilover + Icon UCA, Fox remote reservoir rear shocks, OME Dakar leaf springs
    Hey guys- I have read a lot of posts on Tacomaworld about this TOB issue and the potential that the quill could break.
    Has anyone ever heard of one breaking? I can't seem to find any instances of the quill actually failing- only that the chirp is super annoying.
    My '06 has had the chirp for the last 4 years now and I just hit 120k miles.
  14. Jul 10, 2017 at 9:20 PM
    #154
    eon_blue
    Azusa, CA
    I've never actually heard/read of one failing on here, just a lot of complaints about the dreaded TOB chirp (which I have as well). I replaced my "old" clutch simply because the TOB chirp was driving me nuts and I was afraid of catastrophic failure, only to have the damn thing start chirping again 5k miles after I got a new clutch put in. So now I just live with it.
  15. Jul 10, 2017 at 10:04 PM
    #155
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I saw a post where a failure happened on an FJ.
  16. Jul 11, 2017 at 7:00 AM
    #156
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    mine is super weird it only makes noise sometimes, I know I'm going to need to replace the clutch eventually so hopefully that'll fix it.
  17. Jul 11, 2017 at 10:36 AM
    #157
    NOFINISHLINE
    Fort Worth
    2006 SR5
    Yeah i just don't know what to do-
    Dealer is quoting $1k to replace my clutch and the bearings.
  18. Jul 11, 2017 at 10:52 AM
    #158
    BenJammn5
    BenJammn5 RN
    San Jose
    Mine chirps, been chirping for about 2yrs and I have 85k miles. I was thinking about replacing next year DIY style.
    jc11taco89 likes this.
  19. Jul 11, 2017 at 5:28 PM
    #159
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Mine has been randomly chirping since 35k, it has 50k on it now and not much has changed (knock on wood) I do plan to go with one of the "fixes" in the future. The URD one with the GM parts looks interesting but it gives me diarrhea when I think about having to cut off the quill from my shiny truck x_x
    scottalot likes this.
  20. Jul 12, 2017 at 7:01 AM
    #160
    hladun
    Alberta
    Tacoma
    The slave cylinder spring change I recommend is best done sooner than later. That chirping is wear and damage so the longer you leave it the bigger the problem you've have.
    NOFINISHLINE likes this.
