Great throttle response with air box cracked open
Discussion in '4 Cylinder' started by season818, Nov 15, 2019.
  1. Nov 15, 2019 at 8:34 AM
    season818
    season818 [OP] Active Member
    Shawn
    Colorado
    2013 Tacoma 4x4
    Bilstein 5100, Konig Countersteer Type X
    So, the kind fellas at Jiffy Lube left my 2013 4cyl manual's air box cracked open after they checked my air filter. Obviously, I noticed great throttle response and a throaty sound on my way home.
    From what I've read in these forums, most attribute the atrocious throttle response to the electronic gas pedal, but it looks like the air box + upstream hardware may be more to blame. I'm assuming the air filter was still in place due to vacuum from the engine, so no harm was done, and the problem isn't my air filter. Are there any air box and upstream mods that are commonly done to these 4cyls?
  2. Nov 15, 2019 at 12:01 PM
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    Remove the stationary filter in the lid. Helps a little
    whatstcp likes this.
  3. Nov 15, 2019 at 2:34 PM
    season818
    Shawn
    Colorado
    2013 Tacoma 4x4
    Thanks. I'll go yank that out and report back.
  4. Nov 17, 2019 at 11:57 AM
    JPT4x4ac
    Jon
    Broadalbin , NY
    So... how did you make out?
  5. Nov 17, 2019 at 6:10 PM
    trustyrusty436
    trustyrusty436 Well-Known Member
    2018 Tacoma, auto, 2.7, RWD Access cab, long bed, Utility model
    LCE exhaust header, AF Dymanics CAI, MagnaFlow cat back
    Sounds like you need to change the air filter, you could also drill some holes in the top of the air box or spend $300 on a CAI.
  6. Nov 18, 2019 at 7:58 AM
    96carboard
    96carboard Well-Known Member
    The phenomenon is called "screwing up the sensor readings".
    agalloch07 and dangeroso like this.
  7. Nov 18, 2019 at 8:02 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I think you are imagining that it's more powerful.
    It sounds more powerful, so your subconscious is telling you it is more quick.
    Nevin, honda50r and Yodeville like this.
  8. Nov 18, 2019 at 8:30 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Likely this. Most that have had a cold air intake can attest to this. With the increase in growl/noise, you’re often thinking there is better response. Remove the secondary air filter for a bit better air flow. Generally, Toyota’s or at least Tacoma’s in particular are tapped and don’t benefit to a cold air intake like GM and domestics do. Toyota engineers did well from the factory that there’s not much room for HP gains.
    koditten[QUOTED] likes this.
  9. Nov 18, 2019 at 1:17 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    If they did well from the factory we wouldnt be looking for more horsepower.
    buckmaster243 likes this.
  10. Nov 18, 2019 at 2:30 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Find an intake that gives actual HP verified by a Dyno. I’ll wait.
    If you wanted power, N/A Tacoma’s are not your friend and you bought the wrong truck. Your stock intake is already a ‘cold air’ as it pulls from the inner fender. You gain nothing but resonance sound with an aftermarket intake.
    DGXR, Rcan08, TireFire and 1 other person like this.
  11. Nov 18, 2019 at 8:42 PM
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    I bought a CAI so I could give myself the illusion that my 4 cyl. is more powerful. Whenever I have a passenger, I floor it after a full stop, and then brag about how much power my truck has. No one believes me, but it's good to hear them laugh.
    JGO and koditten[QUOTED] like this.
  12. Nov 19, 2019 at 4:24 AM
    koditten
    Kirk
    Central Michigan
    I'm laughing now. Great post to start my day.
    EZ Harley likes this.
  13. Nov 19, 2019 at 5:17 AM
    Mitch76
    Mitch
    San Angelo, TX
    Keep waiting because no where did i say an intake would give more horsepower. What i was saying was if they had done a better job when the engine was designed (more horsepower) people wouldnt be looking for ways to add more power. It was mainly sarcasm.
    koditten likes this.
  14. Nov 19, 2019 at 8:12 AM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    my mistake. You’re right. I assumed cause you commented on about power on an intake related thread. My Bad
    Mitch76[QUOTED] and koditten like this.
  15. Nov 19, 2019 at 8:32 AM
    Mitch76
    Mitch
    San Angelo, TX
    I really wish it would be as simple as adding some cheap bolt ons to add more power but as we all know its not and toyota made sure of that.
    t.hornstra[QUOTED] likes this.
  16. Nov 19, 2019 at 9:59 AM
    trustyrusty436
    Maybe ya'll should get together and start a Naysayer's thread, for people that already know everything, that there is to know! I wonder why you bother posting to the rest of us!:crazy:
  17. Nov 19, 2019 at 11:16 AM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Most didn’t join knowing everything. Doesn’t mean we can’t make observations and comments on topics that get brought up over and over. There’s a search function that most don’t take advantage of, leading to a lot of duplicate threads and questions.
    Generally, when someone creates a thread with a question, someone with info might respond. That’s how communicating works, isn’t it?
  18. Nov 19, 2019 at 11:29 AM
    96carboard
    I'm confused.... if you're here reading responses, or you're here asking people to endow you with their knowledge, then why do you question when people comply?
  19. Nov 19, 2019 at 11:33 AM
    96carboard
    Its way way simpler than bolt-ons, actually.... they offer an option with a larger engine (note that OP selected the 2.7).
  20. Nov 19, 2019 at 12:50 PM
    Mitch76
    Mitch
    San Angelo, TX
    Or they couldve given both engines more power. But they didnt do that either.
