Great throttle response with air box cracked open
Discussion in '4 Cylinder' started by season818, Nov 15, 2019.
  1. Nov 19, 2019 at 12:52 PM
    96carboard
    96carboard Well-Known Member
    If you think about that for just a moment, you should be able to realize why that makes absolutely no sense.
    koditten likes this.
  2. Nov 19, 2019 at 12:58 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Makes complete sense. Maybe it would be best for you to consider me part of the group you mention in your signature since it appears that its for people that dont agree with you.
  3. Nov 20, 2019 at 7:38 AM
    96carboard
    Yep, I think I will. Clearly it is too complicated for you to comprehend that if they can SELL the smaller engine, it means that people WANT the smaller engine. And why could that possibly be? BECAUSE IT IS SMALLER. It certainly isn't any cheaper.
    Making it bigger would defeat the purpose.
  4. Dec 12, 2019 at 3:08 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    "They offer an option with a larger engine". No, to get the larger engine, you must get a larger Taco. I don't want a larger Taco, I want my little Taco with a reasonable amount of power. I see no need to make an engine with this little power.
    Luke-Maine likes this.
  5. Dec 13, 2019 at 5:22 AM
    96carboard
    They're all the same size.
  6. Dec 13, 2019 at 6:45 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    What the heck does that mean??? Why did you post "They're all the same size"?? What were you trying to say??? I don't understand.
  7. Dec 13, 2019 at 6:54 AM
    96carboard
    Clearly you are incapable of understanding. Too bad for you.
  8. Dec 13, 2019 at 6:58 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  9. Dec 13, 2019 at 7:03 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    LOL. Hint: A larger Tacoma would be a Tundra. The 5.7 has all the power you want. I know, I have one as well as a couple Tacoma's.
  10. Dec 13, 2019 at 12:29 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I can't argue with that, I'm not capable of understanding, that while talking about Taco's you say "They're all are the same size". I'm kind'f embarrassed to ask, but could you explain it so even I can understand?? It will need to be really really simple.
  11. Dec 13, 2019 at 1:27 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Well, I knew they discontinued the reg. cabs about 4 yrs. ago, but just never realized the access cab, W/ 127" wheel base was the same size as the double cab W/ 140" wheel base. I just figured the double cab, was larger than the access cab. The DCLB sure looks bigger than the access cab.
    whatstcp likes this.
  12. Dec 13, 2019 at 4:23 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    Double cab is the same width, but it IS bigger. It's longer, so it is bigger in length, and it's heavier.
  13. Dec 13, 2019 at 4:25 PM
    1moonshine2
    While the Tundra does have a much better power to weight ratio than a Tacoma, it's still very heavy, and as such has less power to weight than some similarly powerful competitor's trucks.
  14. Dec 13, 2019 at 4:49 PM
    koditten
    Kirk
    Central Michigan
    True.
    The tundra still has a shit ton more power to weight than the Tacoma, no matter what flavor Tacoma you get.
  15. Dec 16, 2019 at 11:41 AM
    #35
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Cheap, fast, reliable... pick 2
    Tacomas are relatively cheap and very reliable. They aren't known for horsepower. Personally I would rather have an engine slightly down on power (by design) that is affordable and ultra-reliable. I think that's why the Toyota 4-cylinder engines have a legendary reputation for reliability... they are not tuned to the performance limit of the engine design, so the engines live longer. Even when the 2.7 Tacoma got dual VVT-i (2015?) there wasn't much more zip. It's strange because my Dad's 2006 Highlander base model (2.7) is very responsive right off idle, whereas my 2.7 Tacoma will bog slightly if I just stab the gas off the line. (I think the lack of power in the Tacoma has to do with the PCM programming and other engine tuning between the different models/drivetrains/intended uses of the 2.7, otherwise it's mostly the same engine.) Still my Tacoma does everything I need and I have no intention of modifying the intake.
    Anyone pulling the secondary air filter for better performance may have issues with smog inspections, if required.
    mray, BillsSR5 and koditten like this.
  16. Dec 16, 2019 at 2:31 PM
    #36
    1moonshine2
    The 2.7 in the Highlander is the 1AR-FE, not the 2TR-FE like the Tacoma. They are not the same, the 1AR is all aluminum, and has a different bore, and stroke. Although, maybe not pushed to the
    "limit" the 2TR-FE produces a good per liter power factor for a non forced induction, general purpose production engine. Toyota could have used a larger engine for more power, and still had
    reliability and good performance. The Tacoma is not cheap, it's about 90+ percent the cost of a lower end half ton full sized pickup.
  17. Dec 16, 2019 at 2:43 PM
    #37
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    No doubt very reliable, & that's good. Also no doubt you don't care about power. I have no problem with that. My mother was like you, yrs. ago, she had a Chevy Impala W/ a 6 cyl. auto. & like the 2.7 Taco, very low on power but she thought it was fine. What I'm aggravated about is, then she had options, she could have the 6 cyl. but if she liked a little more power she could get a reasonable powered small V-8 or if she wanted a lot of power there was a big high powered V-8. My problem is, it couldn't be a big deal to put either the little weak 2.7 or the more powerful 4.0 V-6 in the Taco's. You have the option to have either, if you got the extended cab models, & the engine compartment of all the Taco models are exactly the same. If the 4.0 would fit in the extended cab, it would fit just exactly the same in the reg. cab. It couldn't be money, if they charged $1000 extra for the 4.0 in the extended cabs, put the 4.0 in the reg. cab & charge $1000 extra for it. Shirt, I'm still mad & sure wish I could understand "WHY", "WHY", "WHY"??? Oh Gosh, the misery, & "WHY"??? ///
  18. Dec 16, 2019 at 2:45 PM
    #38
    Clearwater Bill
    Billy
    Largo Florida
    That you got right.
    The other, not so much.
  19. Jan 17, 2020 at 6:35 AM
    #39
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    0 to 60 in 4.5 Minutes
  20. Jan 17, 2020 at 6:11 PM
    #40
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    With 4.88’s and 35’s I kept up with my cousin in his TDI until about 45-55 mph.. We were both impressed. If you like driving at the 2500 rpm level these things are always slow, gotta let her live a bit to get any “performance”
    JGO[QUOTED] likes this.
