Great Video on Tacoma Theft and Protecting Yourself
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KVTaco, Jan 18, 2021.
  1. Jan 18, 2021 at 5:51 AM
    KVTaco
    KVTaco [OP] Well-Known Member
  2. Jan 18, 2021 at 5:59 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Yeah been a thing for awhile. Do the same thing with credit cards. RFID blocking wallets and you can turn off your fob to stop sending out the signal. So that for your spare fob too.
    Chew likes this.
  3. Jan 18, 2021 at 5:59 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    I saw this video a while back, and while it is very interesting and somewhat convincing, I am a little confused. I know that if I step about 6ft away from my truck, the doors cannot be unlocked and opened. So I just don't understand how someone is able to steal my FOB code and use it?
  4. Jan 18, 2021 at 6:00 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Your fob is constantly pinging a signal. Just gotta ride the signal, it gets amplified, and saved to the device. It's actually super easy.
  5. Jan 18, 2021 at 6:04 AM
    KVTaco
    The short version:
    Organized crime can steal your FoB signal from 300 feet away
    Copy it onto a blank FoB
    Steal your vehicle now or in the future with it
    Malvolio likes this.
  6. Jan 18, 2021 at 6:06 AM
    363110 Well-Known Member
    Norfolk VA
    16 DCSB TRD Sport 4x4 v6 Manual Towing
    Another reason to buy a MT. No pushbutton start.
  7. Jan 18, 2021 at 6:18 AM
    aozer
    aozer Well-Known Member
    Dallas
    2020 Tacoma TRD OR Cement
    you can also turn off the key when not in use. hold the LOCK button and press the UNLOCK button twice. you should see the light blink 4 times. this means the fob has been turned off and will not be transmitting until it is turned back on (by pressing any one of the buttons).
  8. Jan 18, 2021 at 6:18 AM
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Copy fob code, unlock truck, wire around ignition, drive off.
    rlx02 and 363110[QUOTED] like this.
  9. Jan 18, 2021 at 6:33 AM
    oogielaflick
    Keith
    Man, I just tried that on my FOB, and it worked! Where did you learn that from? COOL!
    rando451 likes this.
  10. Jan 18, 2021 at 6:37 AM
    aozer
    Dallas
    i cant take any credit, i saw it from somebody else on here
  11. Jan 18, 2021 at 6:41 AM
    Draco-REX
    Draco-REX Well-Known Member
    OH
    White 2019 TRD Pro MT
    Too many mods and I haven't even started yet..
    There's a transponder in the key that's read by a sensor at the ignition lck cylinder. They'd have to physically have one of your keys to copy it, and at that point, it's moot. They could still get access to the cab though.
    363110 likes this.
  12. Jan 18, 2021 at 6:42 AM
    Xplosiv
    Jeff
    Lewisville, TX
    Anything can be wired around if they have the know how and the time.
  13. Jan 18, 2021 at 6:50 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Stealing a push button start vehicle requires specific equipment, I don't know how hard it is to get or build since I'm not in the car stealing business.
    But, any moron can pop out the ignition cylinder with a home made dent puller. Not seeing any advantage here, except supporting your local thieves
  14. Jan 18, 2021 at 7:12 AM
    Draco-REX
    OH
    The only fast way to do that would be to swap the ECU with one pre-programmed with a known transponder code. This is how the Evo X gets stolen because the ECU is easily accessed under the hood. In the Tacoma it's buried under the dash.
    Any brute force attempt to get the code would take too long. Better to just bring a repo truck and drive away with it in 30 seconds.
  15. Jan 18, 2021 at 7:35 AM
    CrazyAirborne
    CrazyAirborne Who jumps out of perfectly good airplanes?
    Central Wisconsin
    2017 TRD Sport
    I knew they could do this but didnt realize they had a 300ft range to scoop the transmitters signal. thats ridiculous. Im thinking its time to put in that hidden kill switch.
    363110 likes this.
  16. Jan 18, 2021 at 8:22 AM
    363110
    Norfolk VA
    Valid points from both. I don't mean to say MT can't be stolen. It's just not the same process as what was detailed in the video.
    I've heard that MT is a theft deterrent. I'm not sure if that's because people think thieves can't drive MT or if they'll have a harder time selling it but that's probably only for smash and grab. If the thieves are organized and equipped like the ones in the video it probably doesn't matter.
    I think this is the better solution. Add in a battery kill switch that only you know about.
  17. Jan 18, 2021 at 10:29 AM
    oogielaflick
    Keith
    Now THAT is a good idea, a hidden kill switch! But in thinking about it, it reminded me of the security system that came on my 96 Tacoma when I bought it new back in November of 1995, when the 96's first came out. The dealer installed these "Prolock" on all of the vehicles in the lot, in an effort to stop thieves. It was basically a plug in switch that was mounted under the dash in front of and below the steering wheel, that required you to plug in a computer chip in order for the truck to start. It could not be started without the chip. Now of course, as others have said, anything can be wired around, but it would have taken a LONG time to do it, so in effect, this was a great security device. The chip would clip onto your key ring so you just plugged it in, started the vehicle, and you could then take the chip out or whatever. I had been pretty secure with the keyless entry until I first saw this video and in reading this discussion. Now I am not so sure. I do know that I do not want a pouch of nay kind to put my fob into, as that would really defeat the purpose of having keyless ignition, as it just remains in my pocket and I just walk up to the truck, get in and push the button without having to even touch my FOB. But if I have to get an RF concealing pouch, then I have to take out the FOB, to get into the vehicle and to start it, and then put it back. Completely defeats the purpose of keyless ignition. Now, that all being said, I have to admit that this potential for being able to steal a FOB code does seem to be a serious concern. At the very least, I should probably get out my steeringwheel/brake lock device and start using it again. Wow. I have been pretty happy with my keyless entry for the past almost two years now, despite having misgivings before I bought the truck. Thanks again, for this post...
  18. Jan 18, 2021 at 11:15 AM
    desmodue
    2016 TRD OR AC
    I think this is the better solution. Add in a starter relay kill switch that only you know about
  19. Jan 18, 2021 at 11:17 AM
    Tigris99
    Tigris99 Well-Known Member
    St Louis
    2021 AG Trail edition
    This is one thing that I love about my 21 Trail edition, NO PUSH BUTTON START. For this exact reason. You can order the shit out of China to steal the FOB codes. Cant do that with a key.
  20. Jan 18, 2021 at 11:30 AM
    JmsWms
    JmsWms Well-Known Member
    Jim
    Tennessee
    2017 Inferno TRD Sport AC 4x4
    I agree. Seems like it would just be easier to disable the FOB when you get out of the truck, and then unlock the truck by enabling the FOB when you get back to it. The pouch seems like a lot of trouble. JMO
