Great White Taco build
Discussion in '2nd Gen. Builds (2005-2015)' started by fatfurious2, Mar 28, 2016.
  1. May 5, 2018 at 10:00 AM
    #3561
    fatfurious2
    fatfurious2 [OP] IG: great_white_taco
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @TacoCat tell me more about this pusher/puller fan that I should look into
  2. May 5, 2018 at 12:23 PM
    #3562
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Oh the electric fan? I think its called a flex a lite. A few force fed guys on here have installed them to help push air through the radiators while wheeling. There might have been a couple threads on the subject, or maybe they talked about it in their build threads. I am on my phone but can search for the threads later when i get to a computer.
  3. May 5, 2018 at 12:25 PM
    #3563
    TacoCat
    Johnny-5
    Chantilly, VA
    The electric fan/fans go in front of the radiators and pushes air either by a thermostat, or you could just rig up a rocker switch to flip it on or off whenever you need it.
    fatfurious2[OP] likes this.
  4. May 5, 2018 at 1:44 PM
    #3564
    TacoCat
    Johnny-5
    Chantilly, VA
  5. May 5, 2018 at 1:48 PM
    #3565
    fatfurious2
    David
    Ashburn, VA
    I am currently not in a position to buy a radiator. Danny did my coolant when he did the SC. I should have had the Tstat done too. I guess there is something else to add to the list... Ill be doing my belts soon, as well as the SC belt
  6. May 5, 2018 at 1:54 PM
    #3566
    TacoCat
    Johnny-5
    Chantilly, VA
    Yeah you should have fresh coolant with the SC install so recent. If your temps are creepin with the heat, i think the flex a lite, or the larger aluminum radiator would be the best bet.
  7. May 5, 2018 at 1:55 PM
    #3567
    fatfurious2
    David
    Ashburn, VA
    Highest ive seen was 192. The the tstat opened, and it went back down.
    Doesnt the TRD cap also do something?
    TacoCat[QUOTED] likes this.
  8. May 5, 2018 at 2:03 PM
    #3568
    TacoCat
    Johnny-5
    Chantilly, VA
    192 aint bad at all. If it goes up above 210, i would turn off ac and crank the heat. Not sure what the trd cap does. I figured it was just to be pretty :notsure:
  9. May 5, 2018 at 2:05 PM
    #3569
    TacoCat
    Johnny-5
    Chantilly, VA
    I regularly saw mid to high 190s last summer with the sc.
  10. May 5, 2018 at 2:06 PM
    #3570
    fatfurious2
    David
    Ashburn, VA
    I dont use AC except when defrosting the windows
  11. May 5, 2018 at 2:06 PM
    #3571
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Shit, I see mid 190s when just driving out to green ridge from the hills.
    TaKoToy, TacoCat and fatfurious2[OP] like this.
  12. May 5, 2018 at 2:11 PM
    #3572
    TacoCat
    Johnny-5
    Chantilly, VA
    Thats right i forgot you like heat and humidity :crazy: :rofl:
    If you have done any muddy water crossings, try spraying out the fins real good.
  13. May 5, 2018 at 2:15 PM
    #3573
    fatfurious2
    David
    Ashburn, VA
    Ill do that the next wash
  14. May 5, 2018 at 2:19 PM
    #3574
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I want to do that, and also inspect by brake drums for mud after that recent thread. :rofl:
    Bocsy44 and TacoCat like this.
  15. May 5, 2018 at 2:19 PM
    #3575
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    What are you using to see your temps?
  16. May 5, 2018 at 2:20 PM
    #3576
    TacoCat
    Johnny-5
    Chantilly, VA
    That was entertaining reading.
    David, not sure if you will need a powerwasher, or if a strong stream from a garden hose will do.
    MarX and EatSleepTacos[QUOTED] like this.
  17. May 5, 2018 at 2:26 PM
    #3577
    TacoCat
    Johnny-5
    Chantilly, VA
    For the coolant i used the ultragauge. I had a 6 speed manual so i wasnt able to monitor tranny temps
    MarX[QUOTED] likes this.
  18. May 5, 2018 at 2:28 PM
    #3578
    MarX
    Mark
    NE Kansas
    That's what I'm thinking about getting so I can monitor my tranny temp while towing too. How do you like it?
  19. May 5, 2018 at 2:31 PM
    #3579
    fatfurious2
    David
    Ashburn, VA
    I have a scangauge. Need to program the trans temp in.
    I have both
    MarX[QUOTED] and TacoCat[QUOTED] like this.
  20. May 5, 2018 at 4:47 PM
    #3580
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    I make sure to hit the radiator real good after every trip.
    MarX, TacoCat and fatfurious2[OP] like this.
