Great White Taco build
Discussion in '2nd Gen. Builds (2005-2015)' started by fatfurious2, Mar 28, 2016.
  1. May 18, 2020 at 7:47 PM
    fatfurious2
    fatfurious2 [OP] IG: great_white_taco
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    No way! My focus has been going towards the front end build. Going dual up front. Its going to take a while
    Arcticelf, Bastek[QUOTED] and RobP62 like this.
  2. May 18, 2020 at 7:53 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    They have a tan one now like my black one.
    Before you became a civilian you knew a lot about the people that love you. You cared.
    I had a 25% off coupon when I bought mine. It's a freaking beast and with the proper amount of silicone under the fender washers/nuts it's completely leak free even while pressure washing.
    Seb knows. :fistbump:
    The HF will hold a lot of shit! You're only going to need one.
  3. May 18, 2020 at 7:57 PM
    fatfurious2
    David
    Ashburn, VA
    Only have room for one. But the thing is, not sure if I have room for 50".. Access Cab problems. A 42" or a 36" would be best
    Gunshot-6A and RobP62[QUOTED] like this.
  4. May 18, 2020 at 8:21 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Maybe do a search for shotgun or carbine cases. Shotguns break down and carbines are much shorter rifles.
  5. May 18, 2020 at 8:25 PM
    fatfurious2
    David
    Ashburn, VA
    Thats what Ive been doing today at work.. and looking up driveshaft stuff
    RobP62[QUOTED] likes this.
  6. May 18, 2020 at 8:29 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  7. May 18, 2020 at 8:31 PM
    fatfurious2
    David
    Ashburn, VA
  8. May 18, 2020 at 8:53 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Why was the thread locked down?
  9. May 18, 2020 at 8:55 PM
    fatfurious2
    David
    Ashburn, VA
    Mistake by a mod. No other issues
  10. May 18, 2020 at 9:10 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Don't blame it on a drunken mod! We don't know that's what happened! :p
  11. May 18, 2020 at 9:24 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :facepalm: again!? Do we need to have an intervention? I'll bring the bourbon :devil:
    Bastek and memario1214[QUOTED] like this.
  12. May 19, 2020 at 10:34 AM
    RUSSELLTACO
    RUSSELLTACO Well-Known Member
    Blacksburg Va
    silver shitbox
    bolt ons and autozone decals
    you think tucking my controller out of sight would be a bad thing. Might not be able to see if its working but all the places i can easily mount it without it being hit by gear are out of sight.
  13. May 19, 2020 at 11:09 AM
    fatfurious2
    David
    Ashburn, VA
    maybe? there is a button on mine, so might want to protect that somehow
    RUSSELLTACO[QUOTED] likes this.
  14. May 19, 2020 at 11:14 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    RobP62 likes this.
  15. May 19, 2020 at 11:18 AM
    fatfurious2
    David
    Ashburn, VA
    RUSSELLTACO[QUOTED] and RobP62 like this.
  16. May 19, 2020 at 11:32 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    What's the advantage of a higher wattage controller? This one is 30w. I see some are only 10w.
    RUSSELLTACO likes this.
  17. May 19, 2020 at 11:36 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Based on the area you live in, you might be able to find a Pelican 1700 or 1720 on Craigslist that'd fit the job perfect. Might be a little rough around the edges, but there may be one floating around.
  18. May 19, 2020 at 11:44 AM
    fatfurious2
    David
    Ashburn, VA
    Im searching craigslist and FB marketplace.
    Gunshot-6A[QUOTED] likes this.
  19. May 19, 2020 at 12:23 PM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    A higher amp controller can handle more volts coming in from the panel, the higher the amperage the more panels you could run essentially. I'm no expert in solar so dont quote me here im going off of what I roughly understand as of now. Essentially you'd want to match or have a higher value for the amperage of the controller to the amperage that your solar panel is putting out. The panel I'm going with outputs a max current of 6.47A so my 30A controller could handle three of them if I wanted to that's rounding the 6.47A all to ten I wouldnt want to risk running 4.
  20. May 19, 2020 at 12:33 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Makes sense, thank you very much. I ultimately want to mount the solar panel on the roof of the cap. I have to be very careful how much height I add to the truck overall because I park in a garage in the city and have no other option.
