Great White Taco build
Discussion in '2nd Gen. Builds (2005-2015)' started by fatfurious2, Mar 28, 2016.
  1. May 27, 2020 at 4:28 PM
    fatfurious2
    fatfurious2 [OP] IG: great_white_taco
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Doing UCA gussets on Saturday. Need to ride the bike and work on some projects for myself and Will. So busy
    RobP62 and RUSSELLTACO[QUOTED] like this.
  2. May 27, 2020 at 4:33 PM
    RUSSELLTACO
    RUSSELLTACO Well-Known Member
    Blacksburg Va
    silver shitbox
    bolt ons and autozone decals
    damn youre busy
  3. May 28, 2020 at 5:15 AM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    Hey OP, didn't you have a bedslide or similar at some point? Have a pro/con's list to share?
    RobP62 likes this.
  4. May 28, 2020 at 5:38 AM
    fatfurious2
    David
    Ashburn, VA
    I have had 2.
    First one - For Long Bed. new, new materials were lightweight, easy install, easy to use. Cons - need to drill bed, space outside of bedslide was not usable.
    Second one - for short bed. Used, older model. Didnt need to worry about messing it up. Cons - heavy, older materials were wood and much heavier. Spaces on the sides were not usable. (I used the space in the front, which is why I bought a short bed one)
    If you are looking, $1k new is expensive. It claims it holds 1k lbs fully extended, but im skeptical because our beds are composite vs a ford that has a metal bed. If you're going used, try for a barely used one at the lowest price that you can negotiate. Dont get wood unless your leafs can support it.
    if you cant find anything used, message @eccracer104 to see if you can get a discount from AutoAnything
  5. May 28, 2020 at 5:41 AM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    I'm looking at a used SB Cargo Glide for sub 5hunnit. It's not something I've really thought about, just because new they're out of my price range and they don't pop up used locally. When one did I thought, hmm that would be nice. But now I'm debating if I even want to spend the money when I'm about to build a garage, plus having an SB space is already at a premium.
  6. May 28, 2020 at 5:58 AM
    fatfurious2
    David
    Ashburn, VA
    I would avoid it if it has a wood base. Theyre crazy heavy and like you said, take up room. But if it helps in the long run, might be ok. And you can usually get your $ back when youre done. Also if you have an open bed, it doesn't make that much sense..
    pabstsmeared[QUOTED] likes this.
  7. May 28, 2020 at 9:15 AM
    fatfurious2
    David
    Ashburn, VA
    Camp kitchen box buildout is basically done. If i need more room i can add more boxes
    RobP62, Arcticelf, LocoLocal and 2 others like this.
  8. May 28, 2020 at 9:17 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    wheres the chef boyarde?
    RobP62 likes this.
  9. May 28, 2020 at 9:41 AM
    fatfurious2
    David
    Ashburn, VA
    Dont have any right now. But it will go in the top box with other dry food
  10. May 28, 2020 at 9:46 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    time to put your lcas on so we can go wheelin
  11. May 28, 2020 at 9:50 AM
    fatfurious2
    David
    Ashburn, VA
    Maybe next weekend
  12. May 28, 2020 at 9:51 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    I had a bedslide before and it was super heavy, It was a wooden slide on a steel frame and it weighed a ton. Youll be adding alot of weight to the back of your truck for a small feature.
  13. May 28, 2020 at 12:46 PM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
  14. May 28, 2020 at 3:39 PM
    fatfurious2
    David
    Ashburn, VA
    Plano weatherproof rifle case price dropped to $69 again. Had to get it. Wasnt even looking for it on Amazon :mad:
    RobP62 and EatSleepTacos like this.
  15. May 28, 2020 at 4:05 PM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    I wonder if it would be too overkill to make a maxtrax mount ontop of a plano case? Is that too overlander of me?
    RobP62 likes this.
  16. May 28, 2020 at 4:23 PM
    fatfurious2
    David
    Ashburn, VA
    You can. Ive seen it. I figured out how to do mine. Will reveal in june
  17. May 28, 2020 at 6:34 PM
    fatfurious2
    David
    Ashburn, VA
    @RUSSELLTACO so I wanted to do this. But couldnt find any aluminum bar stock at Home Depot.
    https://www.youtube.com/watch?v=PvXG3UVrLMU
    And I have already tried this, but didnt like it that much:
    https://www.youtube.com/watch?v=8_YfuabZ5gY
    This guy just bolted them to the mount. So i guess his are just for looks.. :rofl: :facepalm:Overlanders..
    https://www.youtube.com/watch?v=BkqN-6cTsMc
    So I found these:
    https://www.homedepot.com/p/Everbil...-Plated-Universal-Clevis-Pin-815468/204276165
    https://www.homedepot.com/p/Everbilt-3-4-in-Zinc-Plated-Hitch-Pin-Clip-809648/204276265
    And in the spirit of re-using/re-purposing things, I found my old sway bar mounting brackets. Made a couple cuts, and got some anger out with a BFH, and boom, they fit over my 1.75" bed rack bars. Im going to measure/drill/tack weld those clevis pins to a piece of 1" flat bar that I have laying around from another project. I will copy that stainless steel wire trick, since I used some of it on my swingout table.
    ^^ this will be happening over the next couple weeks while I get this and some other projects buttoned up.
    RobP62 likes this.
  18. May 28, 2020 at 6:38 PM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    Are they going to be long enough? I may just use pvc and a long bolt to do mine again so i can tighten them against the case
  19. May 28, 2020 at 6:45 PM
    fatfurious2
    David
    Ashburn, VA
    I bought one to test, and for the Maxsa traction boards, yes.
    RUSSELLTACO[QUOTED] likes this.
  20. May 28, 2020 at 6:50 PM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    i need this tent to come in so I can see how much room I’m working with.
