Great White Taco build
Discussion in '2nd Gen. Builds (2005-2015)' started by fatfurious2, Mar 28, 2016.
  1. Dec 3, 2020 at 5:54 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Exactly 1, but he doesn't have the molding anymore.
  2. Dec 3, 2020 at 6:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    $61 each here. Double check the p/n but that saves $60 overall.
    edit: Also, calling McGeorge with your VIN is a quick way to verify the correct p/n. I've had to do it once and the guy was very knowledgeable.
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-drip-molding-7555104051?c=cT03NTU1MS0wNDA1MA==
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-drip-molding-7555204051?c=cT03NTU1Mi0wNDA1MA==
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-drip-molding-clip-7556102020
  3. Dec 3, 2020 at 6:35 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    wanna sell me your suspension and wheels? ill trade you a cbr
  4. Dec 3, 2020 at 8:46 AM
    fatfurious2
    fatfurious2 [OP] IG: great_white_taco
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Thank you!!
  5. Dec 3, 2020 at 8:47 AM
    fatfurious2
    David
    Ashburn, VA
    After the Prinsu and the bed rail caps, the unbuilding will stop. :D
    Then hopefully around August, ill have to start a bunch of new projects.
  6. Dec 4, 2020 at 11:40 AM
    fatfurious2
    David
    Ashburn, VA
    I see it. If only I didn't have to rebuild my coilovers and rear shocks, and get dual fronts. Maybe next year :fingerscrossed:
    Im unbuilding so i can fit my new GFC :D. Also getting married this year too
  7. Dec 8, 2020 at 3:28 PM
    fatfurious2
    David
    Ashburn, VA
  8. Dec 8, 2020 at 4:50 PM
    fatfurious2
    David
    Ashburn, VA
    @Rome604 is this how you wire your BD lights together? I have a sPod, so I dont need a switch or a relay.
  9. Dec 8, 2020 at 4:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have my 6 squadron sports wired in parallel with no problems. Speakers are much different than lights because of ohms and stuff.
    Gunshot-6A and Rome604 like this.
  10. Dec 8, 2020 at 4:55 PM
    fatfurious2
    David
    Ashburn, VA
    so how do you do it? Wire them into two bigger wires? I need a diagram like that to understand. Or a picture to copy. (not that Im doing it any time soon, just for my reference) I do not understand wiring diagrams
  11. Dec 8, 2020 at 4:57 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They’re all the same gauge wire. But just like that second picture pretty much. I have a pair of wires that I run from the spod down to the furthest light. Then the other 5 lights I tapped into that. Hopefully that makes sense.
    Gunshot-6A likes this.
  12. Dec 8, 2020 at 5:00 PM
    fatfurious2
    David
    Ashburn, VA
    OH. That does make sense, but wouldnt the draw be too much? Or do you have a thicker gauge wire coming from the spod?
  13. Dec 8, 2020 at 5:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not for this specific set up. The squadron sports don’t draw many amps and it’s a short run of wire. You are correct though that it’s something to be mindful of.
  14. Dec 8, 2020 at 7:07 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Thanks brother! :cheers::dancingbacon:
  15. Dec 9, 2020 at 6:46 AM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    @EatSleepTacos is right. There are formulas for figuring out what gauge wire you should use. It takes into account the wattage of the light and the distance of the wire. Longer wires need to be larger gauge to prevent voltage drop under load.
    That's all probably too much information for you. Most likely 12 gauge wires (both hot and ground) will be what you need. How many lights (type also) are you planning on putting on a single switch and where are you mounting them?
  16. Dec 9, 2020 at 6:48 AM
    fatfurious2
    David
    Ashburn, VA
    I haven't gotten that far yet. Was just posing the question. But if anything, 2 S2 sports next to the fogs.. I guess I just wanted to clear it in my mind
  17. Dec 9, 2020 at 6:52 AM
    Rome604
    Dave
    Alexandria, VA
    If it's just the two lights on a single switch then you'll be fine with 16 gauge wire for that case. I normally go larger just in case I ever change anything and I want to install larger lights or something...not that I've ever done that :anonymous:
  18. Dec 9, 2020 at 7:15 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    S2 sports draw next to nothing. 14-16ga will be fine
  19. Dec 10, 2020 at 7:48 PM
    fatfurious2
    David
    Ashburn, VA
  20. Dec 11, 2020 at 7:26 AM
    Gunshot-6A
    Conner
    Everett, WA
    Denso. Followed the writeup in the second gen sticky section to the letter.
