Green 4WD indicator blinking, won't engage 4wd or 4wd low
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LittleBlueHilux69, Aug 10, 2022.
  1. Aug 10, 2022 at 3:36 PM
    LittleBlueHilux69
    LittleBlueHilux69 [OP] Breaking Stuff est. '18
    Rapid City, SD
    2019 Toyota Tacoma TRD OR "Rocky"
    Just like what the title says, I woke up this morning and it just started so I have no idea what could have happened. Does anyone have any insight?
    Some background, I went off-roading like two weeks ago but everything was working fine and has been up to today. It drives just like normal, just stuck in 2WD and a blinking green 4wd indicator. No other lights or warnings. I checked the manual and tried looking it up and I haven't found anything solid. The most I've found was the actuator is faulty or gunked up
  2. Aug 10, 2022 at 3:47 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Did a quick search. I’d follow their recommendations
    First check and make sure the vent hose isn't cracked or disconnected from the 4wd actuator on the transfer case, if that's good check the limit switch voltages at the 4wd ECU when the light is flashing as outlined in the thread below and see which one(s) are out of range.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
  3. Aug 10, 2022 at 3:56 PM
    LittleBlueHilux69
    Rapid City, SD
    Thank you very much for the help, however this looks like it's for a 2nd gen. I'm driving a 3rd gen. The vent hose looks fine and the connector isn't loose. Will the 2nd gen still apply to the 3rd gen? Sorry for any dumb questions, this is like the last thing I need right now lol
  4. Aug 10, 2022 at 4:07 PM
    snakeplissken
    snakeplissken Call me Plissken
    Did you drive through any water?
    usmc2msu likes this.
  5. Aug 10, 2022 at 4:10 PM
    LittleBlueHilux69
    Rapid City, SD
    Yes, could that have gotten in the actuator? I thought it was waterproof. It wasn't a river crossing or anything but a substantial puddle is accurate
  6. Aug 10, 2022 at 4:10 PM
    snakeplissken
    Yup that’s the issue. Water intrusion.. had it happen to several members here.
  7. Aug 10, 2022 at 4:11 PM
    LittleBlueHilux69
    Rapid City, SD
    Yikes, what ended up being the fix for them?
  8. Aug 10, 2022 at 4:12 PM
    snakeplissken
    They replaced the unit. It gets corroded fast inside those things.
    LittleBlueHilux69[OP] likes this.
  9. Aug 10, 2022 at 4:14 PM
    LittleBlueHilux69
    Rapid City, SD
    Man I miss a manual transfer case shifter
    33yrsoftoys and 02Duck like this.
  10. Aug 10, 2022 at 4:17 PM
    snakeplissken
    It’s the actuator on the front diff not the transfer case. It’s not sending a signal to the 4x4 system so it won’t engage
  11. Aug 10, 2022 at 4:20 PM
    LittleBlueHilux69
    Rapid City, SD
    And it shows up as the blinking green 4wd indicator? From what I found it was a different warning. Something like "failure to switch from 2h to 4h"
  12. Aug 10, 2022 at 4:20 PM
    snakeplissken
    There is a couple of threads about this. But the cause and effect definitely line up to water = front actuator gets smoked. But I would wait for some members with personal experience of this to chime in.
  13. Aug 10, 2022 at 4:21 PM
    LittleBlueHilux69
    Rapid City, SD
    Got it well I really appreciate it man thank you. Now to see if I can get this sorted lol
  14. Aug 10, 2022 at 4:24 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Some were able to clean theirs, solder the wire connectors directly to the actuator motor and not have to buy a new one.
  15. Aug 10, 2022 at 4:29 PM
    LittleBlueHilux69
    Rapid City, SD
    Im going to give that a shot first, it looks like this will cost me a pretty penny if I bring it to a mechanic or dealership
  16. Aug 10, 2022 at 4:36 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    My 2nd gen Tacomas went into the water plenty of times, and I never had this problem, what's changed that you can't get the truck in water?
  17. Aug 10, 2022 at 4:45 PM
    flacoloco
    flacoloco Well-Known Member
    when it happened to me, it was bc the truck was not completely leveled. it was infuriating bc I was sitting for like 30 mins turning that knob, I called toyota, when thru the steps on the manual and nothing happened, then I was like "ok, send the roadside" then I rolled the trunk to the pavement and the transfer case popped into place.
  18. Aug 10, 2022 at 5:19 PM
    LittleBlueHilux69
    Rapid City, SD
    I've tried on flat and hills and no dice. Also, no codes are being thrown
  19. Aug 10, 2022 at 5:33 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    Try and switch into 4wd / 2wd drive and turn your wheels left to right (not on pavement) while slowly moving forward
  20. Aug 10, 2022 at 6:08 PM
    LittleBlueHilux69
    Rapid City, SD
    Yeah unfortunately nothing :(
