Green Brake Fluid???
Discussion in 'General Automotive' started by Knute, Oct 31, 2020.
  1. Oct 31, 2020 at 1:53 PM
    Knute
    Knute [OP] Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I'm doing the 100 kmile service on 2002 Chevy Trailblazer 2WD with the 4.2L inline 6. The TB has ABS.
    I'm working on the replacing and flushing the old brake fluid. This stuff has been in the TB since we purchase it in 2002. The old DOT3 brake fluid is GREEN. WTH??? o_Oo_O Replacing with Valvoline Syn DOT3. I'm not concerned with compatibility, because Owner's Manual and warnings on the brake reservoir call DOT3.
    In my 30+ years of DIY service, I've never seen GREEN brake fluid. :annoyed: Typically, it is a light clear amber color.
    Did GM use some funky stuff once upon a time?
    Is this a "normal" color?
    Or do I have another problem on hand?
  2. Oct 31, 2020 at 1:54 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Moisture has got into the brake fluid discoloring it?
  3. Oct 31, 2020 at 1:55 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Haven’t noticed that in our 2006 Trailblazer.
    Have noticed it eats fuel level sensors.
  4. Oct 31, 2020 at 2:23 PM
    Knute
    Crap.....thats another task...... Replace fuel filter.
    I can do that when I replace tranny fluid and filter. Serp belt and pulleys too.
    Then back on the Taco for Serp belt and tranny fluid/filter.
    The TB is my daughter's car.
    This Covid crap and employment situation has pushed me to be the family mechanic, landscaper, repairman.......any job we normally hire.......I learn to complete. Materials are less expensive than labor.
    shakerhood likes this.
  5. Oct 31, 2020 at 2:27 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    I believe green means that some funky algae is growing in it and deff needs to be completely fished out and replaced.
  6. Oct 31, 2020 at 3:00 PM
    Knute
    crap, double crap, crap squared.......:annoyed::annoyed::annoyed::annoyed:
    I did notice some "stuff" on the interior wall of the reservoir.o_O I didn't think it was normal. Although, never suspected it to possibly be algae.
    Well, fortunately, I ran out of brake fluid working 1 wheel (right rear). No solids were seen during the bleed, just green. Wasn't able to finish.
    Ok. My thinking. Get a replacement Master Reservoir from Rockauto for about $20. Replace old resv with new, bleed/flush the system. I think I can remove the old resv without introducing air into the master cyl. I have a lube pump that can be used to empty most of the fluid. So, the mess should be manageable.
    Will this plan work?????
    Nothing like an 18 year old car.......:censored::censored::censored:
  7. Oct 31, 2020 at 4:56 PM
    Knute
    Well, I did a bunch of research.
    The green is not likely to be algae. Algae needs sunlight to grow. It is a single cell plant.
    The green is likely to be copper getting leached from the brazing of the brake lines.
    Either way, the fluid needs to be flushed and the reservoir replaced. I'm going to push the TB onto the same maintenance schedule as the Tacoma. Since, I'm the one doing the work........
    Thanks all for the direction. Looks like my simple flush has become a bit more difficult. Looks like I'll be ordering a reservoir and picking up 4 qts of DOT3.
    wrightme43 likes this.
  8. Nov 29, 2020 at 1:54 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Yes GM has had that for years. So much that copper test strips exist for brake fluid. It also somehow pits the abs pump motor and ruins it.
  9. Aug 7, 2022 at 7:50 PM
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    Whoever thought algae could be growing in hydraulic fluid needs some common with that sense.. i dont think algae can grow in any mechanical fluid.. washer fluid, antifreeze, oil, gas, refrigerant.. would be a big no way of anything growing in it. Only chemical reactions either breaking down the chemical into various hydrocarbons or structures from reactions of an external substance getting introduced into the mix.. aint gonna be any life forms or biology happening in there unless its been sitting somewhere for way too long and even then things would only possibly grow on the systems dry areas, inside or outside..
