Green fluid leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by everleet, Aug 7, 2010.
  1. Aug 7, 2010 at 3:51 PM
    everleet
    everleet [OP] Well-Known Member
    NY
    07 SR5 TRD Off Road
    I was rinsing off my truck this morning and as I was spraying the underside, right in the middle dead center, and I noticed the water turning green. There wasn't much but I can't figure it out what it might be. I crawled under and where it was coming from there are no lines I can see. Any ideas? Thanks
  2. Aug 7, 2010 at 3:53 PM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    Probably antifreeze.
  3. Aug 7, 2010 at 3:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Antifreeze on these is pink i believe? Is yours a 4x4? Geal oil leak from the transfer case maybe? Maybe the water is mixing with some excess grease from your zerk fittings on the drivelines?
  4. Aug 7, 2010 at 4:01 PM
    everleet
    NY
    07 SR5 TRD Off Road
    Yup it's a 4x4. That could be it, it was right in that area. Although I greased the fittings about a month ago with standard black grease and this was a pretty bright green.
  5. Aug 8, 2010 at 8:02 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    the a/c refrigerant is bright neon green
  6. Aug 8, 2010 at 8:10 PM
    BLUETACOMA10
    BLUETACOMA10 Well-Known Member
    Kansas
    2012 TRD Off Road
    Window tint
    That's exactly what is judd94. Your a/c condenser has a leak
  7. Aug 9, 2010 at 9:41 AM
    everleet
    NY
    07 SR5 TRD Off Road
    well that is pretty shitty. so the actual oil in the ac compressor is neon green?
  8. Aug 9, 2010 at 9:44 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Lame!
  9. Aug 9, 2010 at 9:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If it's oil, it'll smell like oil and should separate from the water. Anti-freeze tastes sweet since its an alkaline. I'm not recommending drinking it, but you put a little on your finger and touch your tongue to it and spit it out. It's gross but it can help you determine what you're leaking since anti-freeze only comes from one spot.
  10. Aug 9, 2010 at 9:56 AM
    cohrmundt
    cohrmundt Well-Known Member
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    4.88 nitro gears, Detroit rear, Projector headlights, Relentless Fab custom bumpers and sliders, 6" Pro Comp suspension, all pro leafs, 37x13.5x17 toyo open country tires, method racing wheels, Flowmaster exhaust w/cutout, DTLT headers, K&N CAI, URD MAF calibrator, grillcraft grill with 30" and 20" led bars behind, windshield mounted 50" led bar, Infinity 6x9 speakers, Custom box w/MTX 7500 10"sub, MTX 1200 watt amp, blue led gauge cluster and radio mod, URD short shifter, fiberwerx fenders
    yep it is bright green. i just had to replace my a/c condensor line because my powersteering line wasnt mounted right and rubbed a hole in it. it spray green refrigerant everywhere.
  11. Aug 10, 2010 at 4:51 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Found some bright green fluid underneath the truck this evening. Upon closer inspection the suction hose from the ac compressor to the firewall has chaffed through around a clamp, disabling my AC and leaving the compressor unlubricated. :annoyed:
    Gonna try the dealer tomorrow to inquire about the cost of the aluminum/rubber line. I wonder if they will want just an arm or a leg too...:mad:
  12. Aug 10, 2010 at 5:35 PM
    Pbucks
    Pbucks Well-Known Member
    Montgomery County, Md
    09 SR5 Access (sold)
    None yet
    my wife's '09 Ford Taurus X had a bright green fluid leak near the radiator and it turned out to be the AC condenser had a freon oil leak. Because it was caused by a foreign object hitting the condenser warranty did not take care of the $700 it took to repair.
  13. Aug 11, 2010 at 6:47 AM
    cohrmundt
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    tha line i bought the dealership wanted 70 bucks for it. i just used my mechanics dealer discount and knocked it down to 42 bucks. which is way better than tha 90 dollars autozone wanted for it.
  14. Aug 11, 2010 at 1:03 PM
    Fortech
    CANADA
    The line I have busted is dealer only - $185 Canadian plus air freight and taxes.:mad:
  15. Aug 11, 2010 at 1:10 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Fuck, now I gotta check this since my rack was replaced recently.
  16. Aug 11, 2010 at 1:15 PM
    cohrmundt
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    yeah, you better, i had my power steering pump replaced with a heavy duty pump for my 37's. turns out they forgot to clamp the power steering line back away from the a/c line like how it was and i gotta nice little hole and my a/c stopped blowing cold.:mad: luckily they didnt charge me labor to replace it
  17. Aug 11, 2010 at 1:17 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    It's either Lime Koolaid or your truck went nuclear!
  18. Aug 11, 2010 at 1:30 PM
    cohrmundt
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    :rofl:
  19. Feb 2, 2011 at 5:05 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    I just found this green fluid leak this morning when I pulled the truck out to plow snow. I was confused being the antifreeze is pink, I guess I'll check over the AC lines in the morning.
