Green parking brake wire for Pioneer
Discussion in 'Audio & Video' started by jjglass535, Mar 26, 2020.
  1. Mar 26, 2020 at 8:04 AM
    jjglass535
    jjglass535 [OP] Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Just picked up a pioneer DEQ-S1000A dsp. Question is do I have to hook the light green wire to the e brake or could I use a bypass like on most of the newer pioneer head units
  2. Mar 26, 2020 at 8:07 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I would probably just permanently ground it. I assume it works the same as the radio, where you only need the bypasses to enable video playback. This device doesn’t do video so it shouldn’t be a problem. Pioneer menus and settings are all enabled and work properly when the brake wire is permanently grounded, so that would be my suggestion.
  3. Mar 26, 2020 at 8:28 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Thanks Destin ! Could I just tie it in with my amp ground in the back of the truck or should I go through the harness. Probably no difference ?
  4. Mar 26, 2020 at 8:31 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    No difference at all. Ground is ground. I would just combine it with the actual ground of the DSP itself. No need for any more wiring than necessary
  5. Mar 26, 2020 at 8:34 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Awesome, thanks for being so quick on the reply.
    Figured while I'm out of work I'll rewire everything and run my comps active. Got nothing but time right now
  6. Mar 26, 2020 at 12:20 PM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Hey one more question. As it is now I have a t harness with 9 wire and rca adapters. You think I could just plug the adapters into the dsp or should I just go speaker level and use each wire
  7. May 28, 2020 at 5:23 PM
    scmedic85
    scmedic85 Well-Known Member
    Greig
    Charleston, SC
    2012 DCSB 4WD
    I'm trying to hook up my new pioneer dmh-2660nex and having issues with parking brake. idatalink says our trucks don't work with the brake pass through so it has to be tapped directly. Which wire do I need to tap? I don't care to bypass as I don't intend to watch movies on this; I just need to be able to do initial bluetooth setup.
  8. Sep 5, 2020 at 6:51 PM
    baldy54
    baldy54 Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    Did you get it working?? The green Wire Grounded??
  9. Sep 6, 2020 at 8:40 AM
    scmedic85
    Greig
    Charleston, SC
    2012 DCSB 4WD
    Ended up going the bypass route
