Grill and best headlight replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by CC HUNTS, Jan 25, 2016.
  1. Jan 25, 2016 at 6:16 AM
    CC HUNTS
    CC HUNTS [OP] New Member
    Cale
    98 Tacoma 4x4 2.7L
    Reworked frame to remove rust, 2 1/2" flow master exhaust from cab back. 31-10.50-r15
    so I'm new here and I looked for a thread on this but couldn't find one. I hit a deer in my 98 Tacoma and need a new grill and headlights. I have seen a grill that is black and says TOYOTA across the center it has TRD in the bottom corner. I'm wondering if I could get some info on this grill. I googled it and can only find images. Also there are a ton of aftermarket headlights, I don't want halo style projectors but would like a brighter, better beam. Any suggestions?
  2. Jan 25, 2016 at 7:06 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    The grill your talking about is a modified grill or a "Satoshi grill mod" < search engine that phrase and you will get more info on how to make or obtain one.
  3. Jan 25, 2016 at 7:41 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    On the headlights, if you just want a brighter beam, then just don't use the stock bulbs. They can be replaced with brighter (and whiter) ones that are available at most auto parts stores. 'Sylvania Superstar Ultra' bulbs, for example, are around $50 for a pair and can be installed into stock housings.
  4. Jan 25, 2016 at 9:08 AM
    CC HUNTS
    Cale
    98 Tacoma 4x4 2.7L
    Thanks I really like the look. Since I need a new grill anyways I figured why not
