Grill Fading
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoEnthusiast, Sep 22, 2009.
  1. Sep 22, 2009 at 7:40 PM
    TacoEnthusiast
    TacoEnthusiast [OP] Active Member
    Bobby
    Wichita, KS
    05 PreRunner SR5 TRD Sport
    none, nada
    So I noticed that the stock grill on my '05 is starting to fade pretty badly. I was wondering if there is a write up on painting just the black insert part of the stock grill. I tried the search function but all I could find were a million and 1 satoshi mod threads. I have done the BHLM so I can get the grill off just fine. I was wondering if there were any suggestions as far as what paint to use, what grit sandpaper, stuff along those lines. Any suggestions would be helpful.
  2. Sep 22, 2009 at 8:28 PM
    rightspy
    rightspy Junior Modder
    Fr & R plate bumpers, AR Mojave, Bilstein 5100 & Magnaflow SS CB
    depending on how bad the fade is i'd try "Back to Black" first. It may be a Mother's product...can't remember.
  3. Sep 22, 2009 at 9:34 PM
    Reznor88
    Reznor88 Well-Known Member
    Northern California
    '06 PreRunner DC Off Road
    x2
    Mother's Back To Black might do the trick
  4. Sep 22, 2009 at 10:13 PM
    TacoEnthusiast
    Bobby
    Wichita, KS
    none, nada
    Is that something I can get at autozone or o'reilly's or do I need to order it?
  5. Sep 22, 2009 at 10:17 PM
    Reznor88
    Northern California
    Any auto place should have it in their car cleaning/detailing supplies. Even Walmart should carry it.
  6. Sep 22, 2009 at 10:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I've tried the mother's before... didn't seem to do much for me. I didn't try it on the grill so totally worth a shot. Otherwise, probably tape it up and primer/paint it after a light sand 'n clean to promote better adhesion.
  7. Sep 22, 2009 at 10:44 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    if its really bad you could try this
    http://www.urethanesupply.com/closeouts.php
    the rattle can at the top. $4 closeout item :)
    maybe some adhesion promoter after a light sanding then paint?
    then report on how it works
  8. Sep 23, 2009 at 11:49 AM
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    You can use this paste on any surface on the car and it works pretty well. I have used it and it will bring the "black" back to your plastic and trims peices
  9. Sep 23, 2009 at 4:46 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
