Grill issue offer up opinions please
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MadKatt, Dec 22, 2019.
  1. Jan 11, 2020 at 7:03 AM
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    No problem. As you already found water accelerates the process and the heads of bolts will eventually eat right thru the aluminum. I've lifted aluminum plate off of steel before and found 1/4" thick layers of the corrosion residue in places that stayed wet--reefer trailer floors and have seen steel crossmember ends bulge and perforate 1/4" thick heat treated bottom rails as the reaction occcurred.
  2. Jan 11, 2020 at 7:31 AM
    GTCOMA
    GTCOMA Well-Known Member
    OH
    New Truck 2019 TRD Sport - Old Truck 05 TRD Sport
    if I have any issues with mine, I might go the route of drilling out the pems and install bolts that match the perimeter bolts. Here in Ohio, they love to throw all kinds of chemicals on the roads for ice... for now, I will hope for the best that they stay black.
    MadKatt[OP] likes this.
  3. Jan 11, 2020 at 10:45 AM
    MadKatt
    MadKatt [OP] In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Nice I almost went with red but I have the blackout package on mine so I stayed with that. Here in Nebraska it’s like Ohio throw all the crap on the road it eats through everything. In the spring I’m going to reevaluate it I might go with the drilling the pens out shouldn’t be to hard.
  4. Jan 13, 2020 at 5:54 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I don't think so. PEM studs are mechanical fasteners they grip by sinking into the sheet. Even so, welded or mechanical contact- stainless or zinc coated steel pressed into aluminum sheet will still result in galvanic corrosion.
    Also, it can't be welded anyway since you you can't weld steel/stainless steel to aluminum.
