Grill lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by #tacosauceonly, Sep 28, 2019.
  1. Sep 28, 2019 at 3:51 PM
    #tacosauceonly
    #tacosauceonly [OP] Member
    Ben
    2011 double cab long bed, white
    Light bar, light pods on roof rack, headlights, taillights, sound system, suspension, roof rack
    Right now, they're just wired to a constant. So when the trucks on they're on, but I'm trying to see if theres an easy way to have them wired to the headlight switch so I can turn them off too, without having to tear apart the steering column.
  2. Sep 28, 2019 at 6:40 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    So your light bar is always on when your truck is running? Where do you have the relay trigger tapped?
  3. Sep 28, 2019 at 6:47 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I just recently installed a CaliRaised bar in that spot. I added a relay near the battery, and a switch inside. I tapped a light switch switched power in the fuse block under the lt side of the dash for the switch. Mine only work if the lights are on, and they must be turned on to work as well. PM me and I can walk you through the wiring in more detail.
    Pat
  4. Sep 28, 2019 at 6:50 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    How in the world.....
    outxider likes this.
  5. Sep 28, 2019 at 9:59 PM
    caribe makaira
    Caribbean, Puerto Rico
    Add a circuit/fuse at the Low Beam fuse (Left or Right). You'll loose the Lightbar with HIGH Beam select.
  6. Sep 28, 2019 at 11:22 PM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    If he put the add-a-fuse in the turn signal light / hazard fuse (#12 I think), will his raptor lights blink when the blinker is on?
  7. Sep 28, 2019 at 11:45 PM
    caribe makaira
    No...the fuse is before the blinker relay...But there's no switch to control the lightbar, which the OP wants...
    JoshS[QUOTED] likes this.
