Grill Removal and Paint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by polansky568, Jun 26, 2010.
  1. Jun 26, 2010 at 5:31 PM
    polansky568
    polansky568 [OP] Member
    Well hey there
    Got a couple questions. I've got myself a black '09. I'm planning on removing my grill tomorrow morning and giving her a black paint job. First question is this: I scoped it out, and it looks like its 2 screws and 4 tabs to remove. Is there anything tricky about it or what are we looking at? Is it simple or complex?
    Second: My plan is to roll on over to pepboys and purchase a can of krylon fusion black paint, and then krylons clear coat paint. It claims on the can that priming/sanding is not necessary. Is this true or not? Is it really as easy as that? or would you recommend another company.
    Finally, am i making the right decision. I am yet to see black with the black stock grill and in my head, it looks great. But there has been a few things my head glorifies and when I do it, it does not look great.
    Let me know! Thanks!
  2. Jun 26, 2010 at 5:39 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    2 screws and 2 tabs to remove. screws are obviously placed and tabs are to the far left and right of the grill. once those are removed pull straight up on the grill assembly with...eh quite a bit of force and its off. also being a chrome grill i would same with a 400 grit, just to be 100% sure you got the job done the first time
  3. Jun 26, 2010 at 6:32 PM
    polansky568
    Thanks you sir. So, is there any way to screw up the removal of the grill?
  4. Jun 26, 2010 at 7:07 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    No, just pull up after removing the two plastic holders and two metal screws, it is really easy.
  5. Jun 26, 2010 at 7:15 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    When you pull up, pull from the bottom and pull up one side at a time 'carefully' but forcefully. That's about the only caution I would air.
    As for the color question... any black is better than the ghetto chrome right? Worst case senario: go down to the dealer and pay $230 for a color matched Black Sand Pearl (or take yours to a shop for matching).
  6. Jun 26, 2010 at 7:16 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Get some adhesion promoter or self-etching primer so the paint will stick better to the chrome...then you'll be good to go.
    I painted some chrome mirror covers and used the adhesion promoter first (after light sanding) and they have help up fine for a year now.
  7. Jun 27, 2010 at 10:12 AM
    polansky568
    Alright thanks. Any black cant be that off from the black sand pearl right? To the point where it wouldnt really be noticeable?
