grillcraft options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adamw, Aug 4, 2011.
  1. Aug 4, 2011 at 12:13 AM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    I have had my grillcraft insert sitting around a while and was going back and forth with different setups. at first I wanted to do lights behind it, but the wiring and all that kind of steered me away. I like the look but it just seems like a bigger project then I can take. the other setup that I like is the TOYOTA emblem that looks kind of like the FJ grille. does anyone have any other ideas or pictures of what they did? thanks.
  2. Aug 4, 2011 at 12:20 AM
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
    Installed mine in about two hours (both). That includes paint behind grill!
  3. Aug 4, 2011 at 12:31 AM
    adamw
    sunnyvale, CA
    did you take your bumper off to paint behind the grill? did you just mask everything with tape and cover it with paper?
  4. Aug 4, 2011 at 12:41 AM
    1Bigbird
    winter-peg
    2010 TRD D-Cab
    You have to take the grill off (easy), to install the GrillCraft but not the bumper. I took both off then painted but still taped off for the lights and over spray that may get thought the rad during painting.
    The clips for the bumperets is the only place that gave me issues, but still got everything off and back on without braking any clips.
  5. Aug 5, 2011 at 12:38 AM
    adamw
    sunnyvale, CA
    was cutting out the stock grill pretty straight forward? did you run into any complications with fitting it? your truck looks mint btw!:D
  6. Aug 5, 2011 at 4:16 AM
    1Bigbird
    winter-peg
    2010 TRD D-Cab
    Thanks! :D
    Putting the tiny screws in was a pain but straight forward! The hardest part of cutting was starting to cut a grill with no scratches or chips.
