Grille Compatibility
Discussion in '1st Gen. Tacomas (1995-2004)' started by Teke, Mar 21, 2017.
  1. Mar 21, 2017 at 10:17 PM
    Teke
    Teke [OP] Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    So I found an aftermarket front grille that I want to get for a satoshi grille build but it says its only compatible for 95-97 base 2 door tacomas, I have a 96 SR5. I don't see why the grilles would be different but want to make sure it'll work before I spend the money on it. Any input would help. I'll attach the link below. Thanks for the input guys.
    http://www.ebay.com/itm/NEW-FRONT-G...ash=item236d37373f:g:s3UAAOSw~oFXIG6-&vxp=mtr
  2. Mar 22, 2017 at 12:47 AM
    butsack
    butsack Well-Known Member
    SW WA
    1997 Reg cab 3rz auto
    aftermarket cassette player
    IIRC the 4x4 and 2wd have different grille and headlights from 95-97
    but I might be wrong. someone can confirm...
  3. Mar 22, 2017 at 12:51 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It will fit fine it means 95 through 97. On 95 through 97 trucks you can even use the 2wd grille.
    jjsul likes this.
  4. Mar 22, 2017 at 12:58 AM
    butsack
    SW WA
    i thought the 97 2wd looked like this?
    and the 97 4x4 looks like this
    DustStorm4x4 and jjsul like this.
  5. Mar 22, 2017 at 1:01 AM
    Speedytech7
    It was a half year change, 97 was the tipping point for a lot of things. Half way through 97 the 4cyl trucks got coil pack ignition and a new ECU as well as that front end refresh and a couple interior modifications to the radio and climate control area.
    I was talking about this 2WD grille
  6. Mar 22, 2017 at 1:05 AM
    butsack
    SW WA
    :violent:
  7. Mar 22, 2017 at 9:13 AM
    Teke
    Colin
    Indiana
    So it should fit like i thought it would. Sweet. Thank you guys!
  8. Mar 22, 2017 at 7:23 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    Maybe the listing says it fits base models only because it is paintable and not chrome? As far as I know they all fit the same way for that style of grill.
