Grille Lights stay on when truck is off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lazlo, Mar 25, 2020.
  1. Mar 25, 2020 at 3:08 PM
    lazlo
    lazlo [OP] Member
    2019 White Tacoma SR5
    Hey everyone,
    I have a 2019 SR5 and installed the grille raptor lights on my truck that has a ata fuse on it. I currently have it plugged in my INJ fuse but every once in awhile my grille lights are still on when my truck is off, and i'm trying to figure out why it still stays on. Any help will be appreicated.
    Thank you,
  2. Mar 25, 2020 at 3:14 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    How long do they stay on?
  3. Mar 25, 2020 at 3:16 PM
    lazlo
    lazlo [OP] Member
    I've seen it turn off when i turn off the truck then after awhile when I go to lunch I see it back on and I haven't turn the truck on yet or unlocked my doors.
  4. Mar 25, 2020 at 3:18 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I have the exact same situation. Wired my raptor lights to the INJ fuse a year ago and people are frequently telling me "your orange lights are on". No idea why the injectors get intermittent power when truck is off, I'd love to see if anyone knows as well. No problems caused so far but I dont love the situation.
  5. Mar 25, 2020 at 3:21 PM
    TacoTime850
    2019 DCSB 4x4
    Have you guys just tried to use a different fuse? That would be my first step
  6. Mar 25, 2020 at 3:22 PM
    DLRIII
    David
    Baton Rouge
    I want the lights on anytime the vehicle is running, not tied to the other headlight/fog light circuits and I could not find any other fuses with ignition power. I'm considering running it inside to the other fuse panel if it causes me grief.
  7. Mar 25, 2020 at 3:24 PM
    TacoTime850
    2019 DCSB 4x4
    Gotcha. So you don’t want it tied to the DRLs.
  8. Mar 25, 2020 at 3:31 PM
    DLRIII
    David
    Baton Rouge
    That would be fine with me, but the DRL on my truck (SR5) are also the blinker so they have variable voltage and brightness, so if I tied my raptor lights to their fuse I believe they will dim and blink with the blinkers
  9. Mar 25, 2020 at 3:32 PM
    TacoTime850
    2019 DCSB 4x4
    Hmmmm, not sure. Try it out. You will at least gain some knowledge you can pass on to others on here
  10. Mar 25, 2020 at 3:38 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Why would you tap aftermarket accessories into engine management circuits your just asking for trouble...
    GBR, JasonLee, shane100700 and 2 others like this.
  11. Mar 25, 2020 at 3:48 PM
    caribe makaira
    Caribbean, Puerto Rico
    The INJ fuse is part of the same circuit that actuates the post shut down egr test. So when the test is running when most systems are off, it has power, hence anything attached to the INJ fuse also has power.
    Tacoma Mike, GBR, Cpngo and 6 others like this.
  12. Mar 25, 2020 at 3:51 PM
    lazlo
    lazlo [OP] Member
    I'll try that after work
  13. Mar 25, 2020 at 3:52 PM
    lazlo
    lazlo [OP] Member
    Is there any other location to plug into in the fuse box to run DRL or is INJ really the only option for DRL.
  14. Mar 25, 2020 at 3:59 PM
    caribe makaira
    taco_jak, DR TACO and hellfire0480 like this.
  15. Mar 25, 2020 at 4:23 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    This is the same issue as the 'always on fog mod' tapping the power port in the 2nd gens.. the egr runs after a set amount of time after you turn off the truck, for a few minutes the fogs got power if they were turned on..
    DLRIII likes this.
  16. Mar 25, 2020 at 7:51 PM
    DLRIII
    David
    Baton Rouge
    I've got to say, I've seen your posts on other electrical threads and those diagrams are awesome but I dont think im smart enough to actually pull that off lol. Think I'll cause any damage tapping this INJ fuse? I can probably live with the lights coming on occasionally.
  17. Mar 25, 2020 at 7:58 PM
    caribe makaira
    Nope. Just don't add any other illumination to the add-a-fuse branch.
    DLRIII[QUOTED] likes this.
  18. Mar 26, 2020 at 9:37 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    So what fuse in the engine bay did you guys tap? I’m trying some that seem like they should be off but they’re on when the trucks off
  19. Mar 26, 2020 at 11:24 AM
    JeepinDoug
    JeepinDoug Active Member
    Doug
    2019 TRD Pro Tacoma
    none
    I have mine in the same location.
    I read that the INJ system runs a test cycle occasionally, this is why they come on.
    I have had zero problems and not enough draw to damage the INJ circuit.
    Norsemanvike likes this.
  20. Mar 26, 2020 at 11:28 AM
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    I ran my Raptor lights to the INJ and have never seen them on without my TACO being on. I have a '18 TRD Sport.
