Grille Mesh cheap!
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by BYJOSHCOOK, Sep 28, 2016.
  1. Oct 12, 2016 at 10:25 AM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Bump! Would like these sold :D
  2. Oct 14, 2016 at 7:54 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Bump for lowered prices
  3. Oct 18, 2016 at 7:50 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  4. Oct 18, 2016 at 10:07 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I know you want it :boink:
  5. Oct 18, 2016 at 10:09 AM
    FirstGen Jer
    Jeromey
    :D...just giving a :fistbump: for a good deal :thumbsup:
  6. Oct 18, 2016 at 10:13 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Preciate it! Surprised it's still here. But it's not going anywhere so it'll be sold eventually....
    FirstGen Jer[QUOTED] likes this.
  7. Oct 24, 2016 at 5:17 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Monday bump!
  8. Oct 27, 2016 at 9:24 AM
    N8ivFlav
    N8ivFlav Well-Known Member
    aaron
    anchorage,ak
    04 sr5 v6
    Homertaco Satoshi,Weathertech & husky liner floormats, bamf behind grill mount and led bar, leer topper, avs rain deflectors, bug deflector, Bluetooth CD player with 6 switch panel
    I had a 22inch bar and cut & welded the bamf brackets to fit until someone decided they needed a light bar more than I did..., what would be shipping for both light and mesh to 99522 usps parcel select would probably be cheapest to Alaska
  9. Oct 27, 2016 at 10:08 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Let me get better dimensions for the box and stuff since they're odd shaped and I'll get back to you
  10. Oct 29, 2016 at 2:10 PM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Any lower price on the bracket??
  11. Oct 29, 2016 at 6:36 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Nope it's already pretty low considering it would take a few weeks for them to make it plus it's cheaper than there price anyways.
  12. Oct 29, 2016 at 6:50 PM
    JKU3000
    Birmingham, Alabama
    2014 Tacoma
    Hahaha I want it so bad, if it's still here in a few days, I'm buying
    BYJOSHCOOK[OP] likes this.
  13. Oct 31, 2016 at 5:42 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    bump still here
  14. Nov 1, 2016 at 10:17 AM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Josh, Ill take the BAMF bracket. I'll PM you.
  15. Nov 2, 2016 at 5:11 AM
    #35
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Updated OP Bracket has sold, everything else is still available
  16. Nov 8, 2016 at 6:59 AM
    #36
    BYJOSHCOOK
    Josh
    Check Out My Builds
  17. Nov 21, 2016 at 9:20 AM
    #37
    BYJOSHCOOK
    Josh
    Check Out My Builds
  18. Nov 21, 2016 at 12:25 PM
    #38
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Josh, how far apart are the mounting bolt holes? The brackets look like they are the type that can be rotated 180* so the bolt holes are further apart. True?
    Also, What size leds are in the bar? Do you know the total wattage?
  19. Nov 21, 2016 at 12:58 PM
    #39
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I won't be back home until next Sunday but I can figure those answers when I get back if you like. But yes the mounting brackets can be rotated 180*
    Digiratus[QUOTED] likes this.
  20. Nov 21, 2016 at 5:07 PM
    #40
    Digiratus
    Roaming the PNW
    The RedHead
    Thank man, I can wait.
