Grille Mesh cheap!
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by BYJOSHCOOK, Sep 28, 2016.
  1. Nov 28, 2016 at 8:12 AM
    #41
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Sorry Mike I got in late yesterday and forgot to check. But I have it sitting on my bed for when I get home tonight
    Digiratus[QUOTED] likes this.
  2. Nov 28, 2016 at 4:19 PM
    #42
    BYJOSHCOOK
    Josh
    Check Out My Builds
    So the closest the holes can be is 21" and the farthest is 24" and the wattage is 100w, 20 LEDs so 5 watts per
  3. Nov 28, 2016 at 8:05 PM
    #43
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thanks man. That actually sounds pretty close to what I need. Let me do a little measuring tomorrow when its still light out so I can be sure.
    Curious if you bought this new yourself or if it's second hand to you?
  4. Nov 29, 2016 at 4:34 AM
    #44
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Bought second hand, I never used it. And he said he used it for a little bit and took it off. Then was moving and didn't want to bring the stuff with him. I can send you a harness if you want it as well. Just let me know :thumbsup:
  5. Dec 3, 2016 at 6:49 AM
    #45
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Bump for updates OP
