Grille Removal 99 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by jnutter97, Sep 25, 2016.
  1. Sep 25, 2016 at 1:44 PM
    jnutter97
    jnutter97 [OP] Member
    James
    1999 Red Tacoma Xtra Cab SR5 5-Speed Manual
    Hey y'all I'm thinking about repainting my front grille by myself and I couldn't figure out how to take it off. I decided to come here to see if anyone knows how to do it without completely breaking it.
  2. Sep 25, 2016 at 1:51 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  3. Sep 25, 2016 at 2:07 PM
    jnutter97
    James
    Alright thanks man
  4. Sep 25, 2016 at 2:18 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    With a flashlite, look carefully at each of the little black plastic clips. With a long thin screwdriver, you need to just press down (or maybe up) on the protruding part of the clip, and it should pop loose. Repeat.
    On mine, there are 4 on the top (access from the front), and 3 on the bottom (the middle access in front the the side two access from inside, next to the radiator.
    Don't force it. If you don't brake the clips, then the grill will just snap back in when replacing. Even if you break a couple, don't worry. Currently, I'm only using 5 clips, since I broke 2 of them.
    jnutter97[OP] and MTgirl like this.
  5. Sep 25, 2016 at 2:24 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    This.
  6. Sep 25, 2016 at 5:50 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    jnutter97[OP] and FirstGen Jer like this.
  7. Sep 26, 2016 at 5:09 PM
    chilioil.514
    chilioil.514 Well-Known Member
    2003 Tacoma TRD Prerunner 4-Door
    Prodigy P2, Alpine 235BT, Hayden Aux Trans Cooler, Scan Gauge II
    Be careful removing the corner lenses/side markers. Broke the clips when removing them. Luckily Amazon had replacements for a fraction of the price of the dealership.
