Grinding Brake Calipers to fit wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco-gun, Jul 3, 2025.
  1. Jul 3, 2025 at 5:32 PM
    Taco-gun
    Taco-gun [OP] Member
    Gunnar
    2000 Tacoma 3.4
    So I scored a good deal on some 34’s. I already did some cutting to make them fit well and I have a lift kit on the way. When I went to put the wheels on last night, I realize they were close to the calipers But I didn’t know they were going to grind. I’m just wondering if anyone has ground down their calipers so they don’t grind each other. I don’t really want to run spacers because the wheels already have quite a bit of negative offset and they are just barely touching the caliper so I only need to grind off a small amount. Is it safe?
  2. Jul 3, 2025 at 7:05 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I have seen calipers cleaned up for painting by grinding off rough surfaces so I don’t think maybe an 1/8 inch or even a little more would hurt anything.
  3. Jul 3, 2025 at 7:18 PM
    Taco-gun
    Gunnar
    2000 Tacoma 3.4
    Well I couldn’t wait and I ended up shaving it off already. I think I probably only took off 1/16 to 1/8 inch. I can probably fit a piece of paper in between the caliper and the wheel. I’m hoping that is enough clearance.
  4. Jul 3, 2025 at 7:19 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    You are probably good.
    ControlCar likes this.
  5. Jul 3, 2025 at 7:27 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    A quick google search says 1mm is sufficient but preferably 3mm.
  6. Jul 3, 2025 at 7:39 PM
    Taco-gun
    Gunnar
    2000 Tacoma 3.4
    Thanks man! I guess only time will tell. Time to throw on the new lift kit and reboot my CV axels
    t0p_d0g likes this.
  7. Jul 4, 2025 at 5:43 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Just for flex of suspension/hard impact on trails……def get to at least 1mm
    (More than sheet of paper thickness)
    Wulf and t0p_d0g like this.
  8. Jul 4, 2025 at 10:50 PM
    Taco-gun
    Gunnar
    2000 Tacoma 3.4
    Your think grinding them down I’ll be alright? with 34s?
  9. Jul 5, 2025 at 12:00 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    welcome to TW!!
    im assuming these are steelies? soft 8/ d windows?
    agree you need to grind so at least a folded piece of paper fits. the steel wheels will flex and rub more than you expect . 1/8” should be ok, the caliper castings are pretty thick. ymmv, not a lawyer, etc
    ControlCar and Taco-gun[OP] like this.
  10. Jul 5, 2025 at 6:19 AM
    Taco-gun
    Gunnar
    2000 Tacoma 3.4
    Yeah you got the wheels right haha, I am throwing on a lift and new cv boots next week so I’ll do a little more grinding in the close spots so I have more clearance. Thanks for the tips
