Grinding Calipers to Fit Wheels : **How To**
Discussion in 'Wheels & Tires' started by Detective_Dan, Feb 17, 2011.
  1. Feb 18, 2011 at 7:07 AM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i know that, but there are people who want wheels but they dont fit, like myself. make them fit
  2. Feb 18, 2011 at 7:11 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    I like to think these parts are designed a certain way for a reason. Grinding parts to make something fit that wasn't designed to fit is a bad idea. Especially when it comes down to my brakes or wheels.
  3. Feb 18, 2011 at 7:26 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It's a Tacoma thing you wouldn't understand :D
    Pportera likes this.
  4. Feb 18, 2011 at 7:55 AM
    Detective_Dan
    Colorado Springs
    i understand the concern, but i literally only had to grind about 1/16" or less to fit them. they were barely touching, not siezed on the caliper.
    if you are trying to fit them and they are seized to the caliper, its probably not a good idea to grind away
  5. Feb 18, 2011 at 8:19 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That's what I was thinking. I think it would be better to get parts that fit correctly due to this being safty related...that's just my opinion. What I'd be concerned with is not knowing how much material was left after grinding that 1/16" off.
  6. Feb 18, 2011 at 8:26 AM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Its called modifying... :notsure:
  7. Feb 18, 2011 at 8:30 AM
    OffroadToy
    You are correct...that's exactly what it's called!!:cheers:
  8. Feb 18, 2011 at 9:23 AM
    Detective_Dan
    Colorado Springs
    ya thats true, but they are most likely fairly thick becasue of the pressure they have to hold to push the piston
  9. Feb 18, 2011 at 9:24 AM
    Detective_Dan
    Colorado Springs
    mrgrimm has had his calipers like this for over 2 years and he hasnt had a single issue.....
  10. Feb 19, 2011 at 8:35 AM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    The same could be said for Toyota making calipers that are big and protrudeness.(Yeah i made up that word)
  11. Feb 19, 2011 at 8:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And due to the pressures, there isnt alot of room to grind away at the calipers. In the past, people who have done this have experianced stress cracks, or complete failure of the caliper by grinding just a little too much off. Im with Jigz on this one. I dont think its a good idea. Although some people havent had issues, others have. Better off getting the correct wheels for the vehicle. A broken caliper doesnt give the luxury of advanced notice of failure. It generally happens when you need them the most.
  12. Feb 24, 2011 at 1:43 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    I really have my heart set on the procomp/wheelers alloys! Would it be safer to use Wheelers 1/4" spacer that comes with the E/T Ultra stlye lug nuts as apposed to grinding the calipers?
  13. Feb 24, 2011 at 2:06 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I did the exact same thing to fit my wheels, ground down 1/16th on an inch and it was a hairline from the calipers so i added a 1/4 inch spacer and ET lugs, too. My tires stick out a little but i like the look.
  14. Apr 27, 2011 at 1:39 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    i am hand grinding mine with a file mauahahahaha
  15. Apr 27, 2011 at 2:27 PM
    #35
    Detective_Dan
    Colorado Springs
    thats not a caliper lol
    i tried that and it took forever so i busted out the dremmel and i was done in like 10 minutes
  16. Apr 27, 2011 at 2:43 PM
    #36
    Shemicals
    Build Page
    which head piece did u use? i am a dremel noobie
  17. Apr 27, 2011 at 2:49 PM
    #37
    Detective_Dan
    Colorado Springs
    i just used the round sandpaper drum, and one of the metal grinding bits.
  18. Apr 27, 2011 at 3:29 PM
    #38
    Shemicals
    Build Page
    niiiiiice im just grinding the cast bracket. not the actual caliper as i have a 5 lug.
    ill post pichshas afta
  19. Apr 27, 2011 at 5:17 PM
    #39
    Detective_Dan
    Colorado Springs
    alright sweet, hope my thread helped you out!
  20. Apr 27, 2011 at 10:36 PM
    #40
    Shemicals
    Build Page
    i had the bitch jacked up today and my jack set wont fit with my aftermarket lugnuts.... i couldnt get them off.... zomg
