Grinding gear noise again :( [video linked]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eden4x2, Jun 27, 2016.
  1. Jun 28, 2016 at 11:04 AM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Traction control also uses the ABS unit to modulate the brakes. It's all automatic, you don't need to be applying brakes for traction control to kick in. The ABS does not light up. And yes, it feels like a tire rub, but sounds kind of both a tire rub, grinding gear, and leaf spring creaking.
    forty2 likes this.
  2. Jun 28, 2016 at 1:08 PM
    aliu6294
    aliu6294 Member
    All of you who have experienced this noise should look under your trucks for signs of contact by the rearmost U-joint. The leaf-sprung solid axle moves around a lot on hard side loads, and there's not a lot of clearance near that last U-joint.
    I know for me, it ended up fraying the edge of the gas tank skid a little from contact on hard left turns. I've never had it happen on a right turn, but if it does, could be contact with the muffler maybe?
  3. Jun 28, 2016 at 2:01 PM
    stan23
    stan
    Santa Clara, CA
    What are are mentioning is a completely different issue imo.
