Grinding gears when transferring to 4 lo
Discussion in 'Off-Roading & Trails' started by BenWA, Jun 24, 2010.
  1. Jun 24, 2010 at 2:43 PM
    BenWA
    BenWA [OP] Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    How detrimental can it be to do that? I have an automatic (2006 TRD 4x4), and a couple of times I put it in neutral, switched over to 4 lo and then [sloppily] shifted into drive before the 4 lo annunciator stopped blinking... the result was a gear grinding fest until I quickly shifted back into neutral. Is this horrible for the xfer gears/linkages? I feel like my transmission has been behaving strangely since the last time this happened (lurching violently between gear shifts in 4 lo). Thoughts?
  2. Jun 24, 2010 at 2:46 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Why are you shifting into neutral first? I just leave it in Drive and come to a stop before going into 4 Low. Never had a grind. I also have an '06 4x4 TRD
  3. Jun 24, 2010 at 2:54 PM
    BenWA
    Seattle @ 0.9 Mach
    Weird. Mine wont shift into 4 low unless it's in neutral. If I try, the 4 low annunciator blinks and the siren beeps until I put it into neutral and start over. Also, the operators manual says that it has to be in neutral to transfer to low.
  4. Jun 24, 2010 at 2:57 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Who needs instructions?
  5. Jun 24, 2010 at 2:58 PM
    BenWA
    Seattle @ 0.9 Mach
    We pilots take our manuals pretty seriously :p
  6. Jun 24, 2010 at 2:59 PM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I think there is a difference between an AT vs. MT. The MT allows you to be in gear as long as the clutch is pressed. An AT must be in Park or Neutral.
    BTW - I think that is an improvement the Toyota needs to make. I have to try multiple times to get it into 4-Lo, especially when on a hill.
  7. Jun 24, 2010 at 2:59 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Only shift into 4lo while in neutral and at a complete stop.
  8. Jun 24, 2010 at 3:01 PM
    BenWA
    Seattle @ 0.9 Mach
    Same here, and same with locking the diff. Sometimes it takes some serious fiddlefucking to get the diff to lock.
  9. Jun 25, 2010 at 1:05 PM
    BenWA
    Seattle @ 0.9 Mach
    Thanks for the explanations whippersnapper.
    p.s. I used to date a beeeautiful girl from Chino Hills. :) I'm jealous of your climate.
  10. Jun 25, 2010 at 2:17 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Don't get too excited and wait for it to complete the shift into 4 lo before putting it back in drive haha.
  11. Jun 25, 2010 at 5:02 PM
    BenWA
    Seattle @ 0.9 Mach
    Yes, those were the details that I left out. Therein lies the tragedy.
  12. Jun 25, 2010 at 5:54 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    No need to stop completely, a very slow roll is fine, and it will engage easier. But it must be in neutral.
