Grinding into 3rd gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DHRIDER43, Jul 31, 2012.
  1. Jul 31, 2012 at 7:25 PM
    DHRIDER43
    DHRIDER43 [OP] New Member
    Colorado
    05 tacoma sr5 TRD
    I have a 2005 Tacoma 6 speed manual. I have been having some grinding into 3rd gear and I know I am shifting correctly. I just took it into a shop and they believe the retainer that integrates the shifting arm into the transmission is worn out I found the part I need, http://www.villagetoyotaparts.com/showAssembly.aspx?ukey_assembly=340246 (retainer sub-assy, control shift lever). Is it possible to easily replace this from the top without dropping the whole transmission and spending a load of cash for someone who doesn't have a ton of experience working on cars? Any suggestions would be greatly appreciated!
  2. Jul 31, 2012 at 9:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a worn syncro. You may want a second opinion from a shop that specializes in transmissions.
    Scubajules likes this.
  3. Jul 31, 2012 at 9:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Should be top accessable. I havent done it, but lots of guys on here install short shifters, and that would be the same assembly you're looking at having to remove.
    I does sound more like a syncro problem, and that is common on the six speeds, but if this part is cheap, go ahead and try it. I know it was a common wear part on the older 5 speeds, and it was like, 5 bucks.
  4. Jul 31, 2012 at 9:25 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    gonna lean towards syncro...i got my 5th doing it on higher rev changes. I can live with it on 5th but 3rd would def piss me off as that is the money gear on our truck.
  5. Aug 1, 2012 at 2:53 AM
    Blkvulcan
    Blkvulcan Well-Known Member
    Paul
    Augusta, GA
    12 Prerunner SR5
    I agree with the others, worn syncro. I would take it to a transmission shop to get a second opinion. Even if the part is $5 and easy to replace, it would still suck to do the work and not fix the problem.
  6. Aug 1, 2012 at 3:51 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    I agree with the syncro idea. Id get a second opinion.
  7. Jun 22, 2013 at 5:57 PM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Bilstein 5100's . Add-a-Leaf. Interior LED's. Husky floor mats. Thule rack. Various little things...
    I have the same problem recently develop. Glad to see something on here about this. Question though: Whats a syncro?
  8. Jun 22, 2013 at 6:25 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I wouldn't call myself a 3rd gear grinder, but definitely a 3rd gear clunker in some situations. I can feel it clunk past a tooth or two before completely engaging. I suspect the synchronizer also.
    to who just asked, a synchronizer (synchro) is a part on the gear shaft that engages the gear your shifting into before getting all the way into gear. . . if that makes sense. when shifting, you push the clutch in, pull out of current gear, and are in neutral until you grab your next one.
    you can imagine that now your input shaft is completely disconnected and slowing to stationary. your clutch is in so no input from motor, and your in neutral so the input shaft is not "coasting" with your output shaft. now, as you push into your desired gear, you feel that first bit of resistance? that is your sychro engaging its mate on the input shaft and bringing it up to speed. theoretically, you slide the rest of the way into gear once both shafts are turning about the same speed.
    if you've ever driven a jeep, you can hear them when you downshift. goes, whoooooooeeeeeeerrrrrrrrrrrrrCLUNK
  9. Jun 22, 2013 at 6:30 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It's this thingy. They are usually made of some sort of soft metal. Their job is to spool the next gear up to speed so you can shift. If they are worn, grind city. Mine were so bad my truck actually got stuck in third gear. The syncros have been updated to less shitty metal circa 2007 or so.
  10. Jun 22, 2013 at 9:19 PM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    I really appreciate the quick input. I had done some research and found a few threads relating to MT-90 gear oil. Any thoughts on this as a fix or am I still looking at a repair? How much are sychros typically and is it something a novice repair man can attempt? (novice does not include dropping the transmission).
  11. Jun 22, 2013 at 9:58 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    You could do it with a basic tool kit and a weekend, but if you are not mechanically inclined it would be better left to the experts. I can get my trans out on the floor in one hour without air tools or anything fancy, but I've also had it out several times. The syncros require gutting the case and removing all the gears ect. Toyota knew they fu$%ed up on them, that's why they updated them in 07. ALL 05 MT's are suspect. Parts are under $100. Labor will be about $1000 at a shop, twice that at the dealership, and they won't order parts until they have it gutted so figure at least two weeks down time if not more. If you are lucky and under warranty they will install a whole new trans instead of fixing it. Check out http://car-part.com/ and find a used trans out of a newer truck. For your situation that would be the cheapest option, and you could do it yourself or find some inmates from here in your area willing to lend a hand. The MT-90 will help prevent damage. Sorry, but it won't repair gnarfed syncros.
  12. Jun 22, 2013 at 11:56 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    me too, same thing
  13. Jun 23, 2013 at 12:20 AM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Mine started to do the 3rd gear grind and I changed gear oil out to RP and haven't had any grinding issues since. Shifts smoother, I also don't speed shift any more since I'm used to driving it now. Keeping my fingers crossed I don't have any more issues. Slow deliberate shifts and not forcing anything. Seems to do ok now. Going on 2 months since oil change.
  14. Jun 23, 2013 at 1:04 AM
    92dlxman
    Kevin
    Visalia, CA
    I think that is the key, slow, deliberate shifts. don't force anything before the synchro's have had a chance to mesh everything up
  15. Jun 23, 2013 at 4:43 AM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Yep. I usually baby mine. Sometimes I have to get on it cause I live in an area that is full of idiots on a highway where people do 90 in a 55. I will try the gear oil solution first. I can't believe it's that expensive for one synchro!
  16. Jun 23, 2013 at 6:16 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you want to keep the syncros in good shape do not rest your hand on the shifter when driving.
  17. Jul 8, 2013 at 8:33 AM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Dumb question of the day: The gear oil replacement is the same as differential fluid change correct? If so, does that take any specials tools or know how?
  18. Jul 8, 2013 at 1:38 PM
    byrd
    byrd Unknown
    David
    Kansas
    Trans calls for 75W-90 GL-4 or 5
    Diff calls for 80W-90 GL-5, 90W if you don't get below 0°F
    But doubt there will be any harm using either 75-90 or 80-90.
    You want to loosen the fill plug 1st then the drain plug, don't pull the fill plug out till after you start draining or you will get sprayed with gear oil. Under pressure. Takes 1.9 Quarts.
    Use a 24MM or 15/16 size 6-point socket. Might want to get new crush gasket from stealer cost $1.55. Pretty basic, fill plug on side of tranny, drivers side, drain plug on bottom. This is for the 6 spd.
  19. Jul 8, 2013 at 2:03 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    1st, Change to redline mt90
    2nd, do rec'd shifter
    3rd, bring to trans shop.
    There r threads on 1 & 2 to show u how.
    Good luck & let us know how it works out.
  20. Jul 8, 2013 at 2:15 PM
    BamaToy1997
    Bill
    Navarre, FL
    First off, the actual brass part that is being called a synchro is actually called a blocker ring, which is the part of the synchro that does all the hard work. The synchro is the blocker rings (Usually 2 except for 5th gear) as well as the larger outer ring that the shift fork slides back and forth, and a few other small internal parts.
    That is actually a popular myth. Once the gear itself is actually engaged, resting your hand on the shifter handle does no damage to the synchronizer assembly since they are all turning at the same speed, and the synchro ring has already locked into place. What CAN be worn, but rarely so, is the teflon bushing on the shifter fork, which I have had to replace on a few customer's cars over the years.
