Grinding into 5th gear? Any1 else
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twony, Aug 5, 2010.
  1. Aug 5, 2010 at 10:40 AM
    Twony
    Twony [OP] Well-Known Member
    Anthony
    South Philthy
    08 White TRD 6 speed 4x4
    Got alot I want to do but we'll see, that's what the forum is for...
    I have a 08 Access cab 6 speed and lately when I upshift from 4th to 5th mostly when I am on the gas above 3k rpm's it either grinds or I have to gently wait for it to go into gear. Down shift from 6th is fine, any1 else ever had this issue or heard of? Thank god for warranty
  2. Aug 5, 2010 at 2:18 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Pretty much everyone that has an X-Runner complains about this. However, it is usually closer to the 5000 RPM level.
  3. Aug 6, 2010 at 8:49 AM
    Twony
    Anthony
    South Philthy
    Thanks for the heads up, @ least I'm not the only one. I will check out that board
  4. Aug 10, 2010 at 9:39 PM
    Twony
    Anthony
    South Philthy
    Took it to Toyota dealer today & multi parts order about 3 weeks away. They want to rebuild the trans with updated parts, throw out bear, synchronizer... ext, I have 28k & they are covering it plus I have a 7 year 100k wart. Hope all goes well, I will be skipping 5th for now but 3rd seems to be doing as well on the ride home... I saw another post about humming noise @ idle or bussing... Will update as I know more.
  5. Aug 10, 2010 at 11:17 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine will grind 4th on upshift at high rpm. Only happens sometimes. As far as the dealer is concerned, I am a liar who does not have a clue how to operate a clutch.
  6. Aug 20, 2010 at 8:52 AM
    Twony
    Anthony
    South Philthy
    Finally heard back from the dealer, trans rebuild is going to be finished today, they did the rear tsb for the suspension and fixed my creeky clutch pedal also under a tsb. Gotta love warranty.
  7. Aug 20, 2010 at 8:53 AM
    Twony
    Anthony
    South Philthy
    Good luck getting them to resolve your issue. Request to take a tech for a ride, I have heard that will show them the issue.
