"Grinding" is a necessity...
Discussion in '4 Cylinder' started by dgjones, Dec 19, 2009.
  1. Dec 19, 2009 at 5:44 PM
    dgjones
    dgjones [OP] Well-Known Member
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Hi there! It is winter here in Indiana now and with our first snow I realized how easy it is for my 09 Taco (standard everything) to loose grip. I have electronic traction control. I know it is completely normal, but there is the most unhealthy noise that comes from by truck when the rear end starts to lose grip. I was just curious what kind of mechanical things are happening to make this noise. It's almost like the noise from anti lock brakes, but worse. Thanks!!
  2. Dec 19, 2009 at 6:08 PM
    jandrews
    '09 FourDubDee TRD OR
    If you start to lose control and VSC kicks in (beeping, etc) the noise you're hearing is the brakes kicking in. Most of these traction control systems involve the brakes in some fashion to control wheelspin/torque.
  3. Dec 20, 2009 at 12:22 PM
    RichXKU
    RichXKU Active Member
    Rich
    Berks, PA
    '06 reg. cab 4x4 2.7 5MT
    K&N (Previous owner), DIY OEM Cruise, DIY OEM Int. Wipers
    Yep, rest assured its a very good noise, as the lack of it would probably mean you'd be facing the opposite direction quickly - or doing a one legger in the snow :)
  4. Dec 20, 2009 at 5:47 PM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Right on!! That makes sense now!! thanks alot!
  5. Dec 23, 2009 at 6:05 PM
    Yota1
    Yota1 Well-Known Member
    ABS makes a lot of noise, in all cars, sucks, and i find it aggravating. although 99% of the time it is the difference between stopping and crashing, I do wish you could dis-able it
