Grinding noise after steering rack replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NBourque, May 20, 2019.
  1. May 20, 2019 at 8:25 AM
    NBourque
    NBourque [OP] Well-Known Member
    Nick
    Maine
    ‘21 PRO
    So I had a shop install a new steering rack last week. I had an alignment a few days later. All in all it was a good fix. It cured a vibration I had at 45-50. I noticed there is this grinding noise at slower speeds and when I make a left or right turn. The sound isn’t always there but a lot of the time. This noise was not present prior to the rack replacement. Any ideas what it could be? I’m having the shop that did the work look at it tomorrow.
  2. May 20, 2019 at 2:21 PM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Anyone?
  3. May 20, 2019 at 2:28 PM
    DougSD
    DougSD Well-Known Member
    Doug
    San Diego, CA
    2015 TRD Tacoma
    Icon front 2.5 Coilovers, Fox 2.0 rear shocks, Hankook A/T tires
    Air in the system? Take it back to the shop that installed it..have them remedy it.. its only been a week..should perform like new, no noise
  4. May 20, 2019 at 2:31 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    They could have bent the dust shields near the rotors while working In that area. Pretty common and easy to fix. Just pull back the dust shields and make sure there clear and not touching.
  5. May 20, 2019 at 4:25 PM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Ya I’ll see what they say tomorrow.
  6. Oct 24, 2022 at 9:50 PM
    RoadaTyota
    RoadaTyota New Member
    Amanda
    '08 tacoma
    So what was it???
    ...got same prblm
  7. Oct 24, 2022 at 10:58 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    If it’s when your turning or putting a little load on the tires going around a sweeping corner and it making a tisk tisk noise or sounds like there’s a rock in the brakes it’s probably a bent dust shield. Take the tire off and make sure it’s not too close to the rotors. They are pretty easy to bend.
