Grinding noise at high speed decel.
Discussion in '4 Cylinder' started by billy_oliver880, Aug 2, 2009.
  1. Aug 2, 2009 at 9:11 PM
    billy_oliver880
    billy_oliver880 [OP] Member
    Tony
    Mount Horeb, WI
    Hi Folks,
    Just bought my regular cab sr5 with the 2.7 ltr and manual trans 3 weeks ago with 35000 miles. I have taking a couple of long weekend trips with it already and it is quite nice. But when I am on 4 lane doing an indicated 80-85 mph and I take my foot off the gas I get a metallic grinding noise from the rear of the vehicle. I don't get it all the time and it seemed to settle down after fueling up? Any ideas on what to look for? I will be talking to the dealership but I would like to know what I should be looking for first.
    Also when shifting I have noticed that the rpms when shifting do no drop when im shifting from 4th gear to 5th. I push the clutch in and wait to see and finally it will drop if I pause for 3 or 4 seconds but to me that seems very strange.
    Thanks folks for any help you might have!
  2. Aug 2, 2009 at 9:17 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    the throttle sorta lingers, its electronic now, takes a little getting used to. The grind..., tough one, could it be the ring gears? change the gear oil?
  3. Aug 2, 2009 at 9:59 PM
    billy_oliver880
    Tony
    Mount Horeb, WI
    It goes away if you get back into the throttle and does not go away when you hit the brakes. I will let the dealership worry about it.
  4. Aug 3, 2009 at 8:57 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    The grinding noise sounds like your pinion angle is incorrect, I would check to make sure the u-bolts are tightened or just a good physical inspection of the driveshaft to see if the 3rd member are inline with each other.
    As for your RPM's not dropping, check the throttle plate and the return spring (sometimes crap likes to get in there).
  5. Aug 3, 2009 at 9:24 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Are you sure it isn't just the brakes?
  6. Aug 3, 2009 at 10:23 AM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    06 Std Cab 2.7L 4X4
  7. Aug 3, 2009 at 3:45 PM
    Tacoyota
    08 4wd
    2nd gen is fly by wire, no throttle linkage n such
  8. Aug 4, 2009 at 12:12 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
