Grinding noise from engine/rough idle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Feb 10, 2024.
  1. Feb 11, 2024 at 5:44 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I will I was thinking pcv valve but I never heard anyone else’s truck make that noise and it’s not coming from the pcv when noise happens I feel it in the valve cover towards the front . Don’t feel in on the pcv valvev
  2. Feb 11, 2024 at 5:45 AM
    Gfenza89
    Listen closely it’s pretty bad. It comes on and off
  3. Feb 11, 2024 at 5:46 AM
    Gfenza89
    Maybe I exaggerated little bit, rough as in the cab shakes at idle, and a overall roughness vibration when accelerating
  4. Feb 11, 2024 at 5:46 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Had an intermittent grinding noise in our 2015 minivan with the 3.5. Not to freak you out but Toyota basically did a rebuild. I thought it was the water pump based on posts about it think it had something to do with the timing chain system. It just made it under warranty so it didn’t cost us anything, but I was surprised. That happened right after I bought my 2019 lol. No issues with my truck though. Also I think they had to remove the motor in the van because it’s transverse mounting in there.
    Gfenza89[QUOTED][OP] likes this.
  5. Feb 11, 2024 at 5:55 AM
    Gfenza89
    Thanks man I hope not
  6. Feb 11, 2024 at 6:34 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I want to say my 2022 makes the same noises as your first video as did my 2021. Both didn't have the vacuum pump being offroads. :notsure:
    Gfenza89[OP] likes this.
  7. Feb 11, 2024 at 6:35 AM
    Gfenza89
    Interesting. Not a grinding noise though?
    Delta09[QUOTED] likes this.
  8. Feb 11, 2024 at 6:38 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I don't hear a grinding in your video, just the typical loud injectors/HP fuel pump noise.
  9. Feb 11, 2024 at 6:38 AM
    Gfenza89
    Did you watch both videos?
  10. Feb 11, 2024 at 6:42 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I did, however I work in a very loud industrial environment so my hearing isn't as good as normal people.
    Only thing you can do at this point is make an appointment at the dealer. Don't touch a thing. I would bet money they say it's normal, however it will be documented.
    4Stents and Gfenza89[QUOTED][OP] like this.
  11. Feb 11, 2024 at 6:56 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You got a problem there dude I don't think it's a good ideal to be driving that truck around the noise is not normal unless you don't mind walking. Time to pester the dealer.
  12. Feb 11, 2024 at 6:58 AM
    Gfenza89
    Yep Tuesday it goes in. I’m glad I have video evidence
  13. Feb 11, 2024 at 7:51 AM
    Drippy4x4
    Drippy4x4 Keeper of the Air Dam
    '22 SR5 Taco
    Sounds like my '22 with the vacuum pump noise. The second video almost sounds like the vsv purge valve for the evap.
    https://youtu.be/a7lyCoRnOIg
  14. Feb 11, 2024 at 7:55 AM
    Gfenza89
    I don’t know that grinding rattle noise is abnormal
  15. Feb 11, 2024 at 7:59 AM
    #35
    Drippy4x4
    '22 SR5 Taco
    Then it may be my ears or the sound is really amplify thru the mic.
    Good luck and update us with what you find out. I'm curious about the noise too.
  16. Feb 11, 2024 at 7:59 AM
    #36
    Gfenza89
    I will
  17. Feb 11, 2024 at 8:01 AM
    #37
    Gfenza89
    I’m thinking it’s possibly the flaps inside the manifold. The Acis
  18. Feb 11, 2024 at 8:05 AM
    #38
    Drippy4x4
    '22 SR5 Taco
    My understanding is the plastic flap would not open at idle, only at higher rpms. Unless the stupid thing wouldn't closed all the way. But that would still trigger a CEL.
  19. Feb 11, 2024 at 8:58 AM
    #39
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    who thinks Toyota will say this is normal?
    Gfenza89[OP] and Delta09 like this.
  20. Feb 11, 2024 at 9:00 AM
    #40
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I had the same thought.
