Grinding noise from engine/rough idle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Feb 10, 2024.
  1. Feb 12, 2024 at 8:04 PM
    #61
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    Get the truck to dealer before there is damage done to engine
    Gfenza89[OP] likes this.
  2. Feb 12, 2024 at 9:59 PM
    #62
    Tacofan89
    Tacofan89 Well-Known Member
    2016 Inferno TRD Off-Road
    Good luck getting it diagnosed, hopefully nothing too serious. It’s hard not be worried about something that is such a big investment.
  3. Feb 12, 2024 at 10:14 PM
    #63
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    If the heater was on, the AC was probably on.
  4. Feb 13, 2024 at 3:13 AM
    #64
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    It’s not coming from the a/c. It’s coming from the intake manifold or valve cover to the best of my ears. It’s isolated in that are of the engine.
  5. Feb 13, 2024 at 3:14 AM
    #65
    Gfenza89
  6. Feb 13, 2024 at 11:53 AM
    #66
    afd73
    afd73 Member
    My 2017 3.5 is in the shop right now, valve seals with only 70k mi ugh..... anyways the tech found a surprisingly loose plug the left bank # 3 cylinder. could be your problem.
    Steves104x4 and Gfenza89[OP] like this.
  7. Feb 13, 2024 at 3:02 PM
    #67
    Gfenza89
    Maybe I’m hoping it’s something that simple. Sucks what your going through
  8. Feb 14, 2024 at 5:26 PM
    #68
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    That sucks. Wonder how much for the repair if you don’t mind
  9. Feb 14, 2024 at 6:31 PM
    #69
    Gfenza89
    Mine goes into tomorrow morning. Was supposed to be Tuesday it the tech wasn’t feeling good.
    Junkhead likes this.
  10. Feb 15, 2024 at 9:20 AM
    #70
    Gfenza89
    Just got back from the dealership and they claimed the “grinding” noise from the engine was considered normal, sent the video to the engineering department. As for the rough idle the engineer told the dealer that knock value is little high and the fuel trim is a little low. Was told it could be too much ethanol or additives in the fuel and advised me to run high test fuel . The thing is, I’ve been running 93 octane fuel from Exxon or shell. So I’m assuming if I was running 87 then these numbers that are out of spec would be even more out of spec. They scheduled an appointment with a field tech in couple weeks. Knock value was at 26.7
    Steves104x4 and Canadian Caber like this.
  11. Feb 15, 2024 at 6:44 PM
    #71
    Drippy4x4
    Drippy4x4 Keeper of the Air Dam
    '22 SR5 Taco
    While you wait for your next appointment.
    I would disconnect the negative battery cable and let it "reset" overnight. Then go burn a tank of gas and refill it with a lower grade gas. See if anything changes.
  12. Feb 15, 2024 at 6:45 PM
    #72
    Gfenza89
    Will do thanks
  13. Feb 23, 2024 at 9:28 AM
    #73
    ccjiv94
    ccjiv94 Not Mechanically-Inclined
    Colin
    Hanover, MD
    2021 Tacoma TRD Off-Road 4x4
    Magnuson Supercharger OTT SC MT Tune (Spicy) 3-inch Lift & Leveling Kit Morimoto Headlights & 3rd Brake Light AlphaRex Tail Lights KMC Recon Rims BFG All-Terrain Tires Fab Four Front Bumper Victory 4x4 Rear Bumper w/ Swingarms Fox Front & Rear Suspension Upgrade Baja Designs Auxiliary Lighting (S8, Onx6, & Squadron) Bantam SPod System Prinsu Roof Rack Meso Customs Interior Map/Dome Light
    Might be a bit late to the thread but I've been experiencing a similar grinding/rattling/rubbing noise that seems to emit from somewhere on the front driver's side of the truck. I have a '21 TRD OR 4x4 with multiple modification installed. I'm going on over a year of troubleshooting the issue and even had the vehicle taken to a Toyota dealership and paid for the "30k mile complete maintenance/service" package that they offer and also added the 4x4 maintenance service package including inspecting the differentials, etc. The Toyota technicians said that there were not any issues observed across any of their maintenance/service/inspections. I've also cleaned the MAF sensor as well as cleaning out the entire throttle body. The issue has yet to be resolved. There seems to be no effect on the RPMs when the noise occurs. The noise appears during idle after the truck has warmed up after start and the noise also appears around 900RPM or 1100RPM in low gear only--typically in 2nd gear. I've also noticed the noise to occur more consistently at idle when the truck is on level ground or a downhill grade, but seems to be less consistent when idle on an uphill grade. If the noise occurs at idle but continues to idle, the noise seems to consistently disappear after idling for a short time. Activating the heating/AC can cause the noise to appear, but only within the aforementioned RPM ranges. My truck is supercharged, so I typically run at least 91 octane but typically can only find 93 octane out here where I am at on the US east coast (the pumps seem to not offer 91 octane out here). I only fuel up at gas stations with top-tier gas or whatever it's referred to as. I've also put a can of octane booster through a tank of 93 octane to rule out the fact that the octane level could be causing the issue. I'm currently trying to narrow the issue down to possibly being caused by butane content in winter-blend fuel. Other things I have not yet looked into is replacing the fuel filter, having the spark plugs inspected. The truck has also not thrown any visible codes, nor has a check engine light ever illuminated due to the issue. Having the OTT tune applied did not affect the issue as well (I assumed it would not, but wondered if having more power on the low-end would eliminate the opportunities for the noise to occur.) I'm also beginning to wonder if the issue just occurs as part of exhaust resonance. I have an aftermarket catback exhaust and I'd read another forum post about the noise and vibrations caused by exhaust resonance on some Tacomas. The issue does not seem to affect performance in any way, and I am not mechanically inclined but am a very analytical person and I wanted to contribute my analysis so far for the rest of the TacomaWorld users that might see this.
  14. Feb 23, 2024 at 10:04 AM
    #74
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    just remove the supercharger , who are you kidding its just a truck lol;)
