Grinding noise from front differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by btle29, Jun 24, 2014.
  1. Jun 24, 2014 at 7:24 PM
    btle29
    btle29 [OP] Member
    Hey TW .. After re gearing to a 4.88 for my 35" tires.. I am hearing some grinding noise coming from the front differential when let go of the gas pedal speed @ 25mph ( off load) this noise only happened when I put on 4x4 mode.
    2014 tacoma 4x4
    Pro comp 6" lift
    35x12.5x20
    Nitro gears set
  2. Jun 24, 2014 at 7:28 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Doesn't sound good, subbed for the answer, did you install the gears?
  3. Jun 24, 2014 at 7:54 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Sounds like they weren't set up correctly, take it back to who ever set them up and have it looked at. Hopefully the installer will stand behind his work. I went through this on my 09 and Chase @ ecgs made it right.
  4. Jun 24, 2014 at 10:40 PM
    btle29
    btle29 [OP] Member
    Unfortunately I had 2 parties did my gears. One guy at 4 wheel parts installed the gears and another guy remove and reinstall the differentials .. Now they're pointing fingers ..btw N0rth... So what was wrong with your 09 ?
  5. Jun 25, 2014 at 6:01 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    How were the gears shimmed?
  6. Jun 25, 2014 at 1:38 PM
    btle29
    btle29 [OP] Member
    I have no idea... You think it's something wrong internal gears problem ?
  7. Jun 25, 2014 at 2:18 PM
    n0rth
    J.W.
    New Mexico
    There is art to setting gears up and even pros don't always get it right. The other issues could be the ADD (automatic differential disconnect) there is a fork that can end up on the "wrong" side of the collar resulting in the front wheels remaining locked even when in 2 wheel drive the front diff will continue to spin even though the transfer case is not engaged. The issues I had with my front diff was a bad pinion seal after installing the gears which ended up cooking a bearing and required new gears and bearing with less than 500 miles on the front diff. Have you changed the oil in it yet and checked for metal?
  8. Jun 26, 2014 at 5:21 AM
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    Absolutely right. Shimming the gears properly is a must. There is certainly an art to it and the person who installed them needs to get it right...
