Grinding noise from front right wheel. 2020 OR 4x4
Discussion in 'Technical Chat' started by GarlicFarts, May 13, 2020.
  1. May 13, 2020 at 6:56 PM
    GarlicFarts
    GarlicFarts [OP] Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Videos linked here.
    Sound started after beating it in the woods. In the woods it was a constant high pitch squeal. Now it’s just a rubbing sound at each rotation of the wheel. Can’t take wheel off right now since dealer cross threaded some lug nuts.
    anyone know where to look? Sound is a lot worse when wet.
    One is truck on the ground on springs and rocking it. Other is with the jack under the LCA to get the wheel in the air and free spinning it.
    https://streamable.com/onu8ni
    https://streamable.com/fa1q1y
    ps yes this is from the same trail ride as this thread. https://www.tacomaworld.com/threads/toyota-says-i-have-lots-of-damages.665284/
  2. May 13, 2020 at 7:31 PM
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    hard to say with the videos but it sounds like it might be a bend backing plate making contact with the rotor, try and see if it is bent at all and rubbing.
  3. May 14, 2020 at 3:10 AM
    GarlicFarts
    Lil Rhody
    once I can take my wheel off I’ll check that. But wouldn’t that be constant grinding? This sound happens once poppet revolution.
  4. May 14, 2020 at 2:03 PM
    270wsm
    270wsm Well-Known Member
    AZ
    ⬆️ could be that dust shield fr brakes
  5. May 15, 2020 at 6:27 AM
    GarlicFarts
    Lil Rhody
    Update: Toyota replaced 3x lugs/studs after cross-threading during the service. The service advisor basically told me "This isn't a warranty job, so he's just doing it this one time" - I didn't have the time to tell him "You have the time to do this every time you screw up a customer's vehicle", especially since I had already decided I'll never be going back there for service anyway. Basically tried to strong arm me into saying it was my fault and my responsibility they NASCAR whipped the lugs on and jacked it up.
    :annoyed:
    ANYWAY, think it must have been a rock in there somewhere, since after they (I assume) had to remove the brake caliper for the front studs, no more noise. That was what I was planning on doing first when I went to take the wheel off, but got pushed out since I couldn't take the wheel off....
  6. May 15, 2020 at 4:45 PM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    Yes...could be backing plate bent or something lodged in the brake or backing plate.
