grinding noise from rear end and other issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by escomatt, Feb 8, 2012.
  1. Feb 8, 2012 at 2:17 PM
    escomatt
    escomatt [OP] Member
    matt
    escondido, ca
    03 tacoma
    bone stock
    hey im matt. this is my first post here. i have a 2003 tacoma with a 2rz motor. my first issue is that im hearing a grinding noise coming from the rear end when im driving in 5th gear at low rpms. my second issue is that i recently changes my spark plugs and when i pulled the coil packs, the one from the cylinder furthest back looked rusty and oily. the truck doesnt really have the power that i feel it should and i feel like these issues are contributing to it. i also just turned 214,000 miles. any idea what could be wrong?
  2. Feb 9, 2012 at 8:47 AM
    escomatt
    matt
    escondido, ca
    03 tacoma
    bone stock
  3. Feb 9, 2012 at 9:27 AM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    Ah when you told me on the phone you had oil on the coils I thought you meant suspension coils ...def not CV boot lol
  4. Feb 9, 2012 at 9:31 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Try checking/changing out your u-joints. Ive had ujoints that seemed fine on inspection, but it wasnt until you removed them and inspected you could see the wear.
    Also check your backing plate lip grinding on your drum.. long shot but happened to me.
  5. Feb 9, 2012 at 9:33 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    The grinding noise not 100# sure but maybe brakes. Or 3rd member but that's weird it's only in 5. Have you ever serviced your tranny may have a sync going out.
    And oil on the coil id check the compression on that cylinder the rings may be bad.
    Sorry I'm not much help but it's a start
    Good luck
  6. Feb 11, 2012 at 12:35 AM
    escomatt
    matt
    escondido, ca
    03 tacoma
    bone stock
    right on any suggestion helps. ya im thinking that the ring on the 4th cylinder might be bad. and about the u joints thats good idea. ill take a look at it tomorrow morning. thanks for the help guys
  7. Feb 11, 2012 at 9:23 AM
    96Taco
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Yeah u-joints can show a bunch of different symptoms. My friends truck you could tell only when he was going up hills. Mine started bad just going from forward to reverse, before it was crunching the whole time.
