Grinding noise in reverse gear only
Discussion in '1st Gen. Tacomas (1995-2004)' started by Edie011, Mar 30, 2015.
  1. Mar 30, 2015 at 7:50 AM
    Edie011
    Edie011 [OP] Well-Known Member
    Central ohio
    2004 Tacoma trd xtracab
    Hi all I just bought an 04 trd with a 3.4l 5 speed and when you are in reverse gear going backwards it grinds. Only in reverse and only when moving backwards, if you take it out of gear and go backwards it stops. Any help would be appreciated!
  2. Mar 30, 2015 at 8:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    All reverse gears make sort of a meshing/grinding sound. It is because reverse gears are straight cut rather than helical. The forward gears are helical cut which makes them quiet but slightly less strong, the reverse gear is straight cut and it is rather noisy. This is a common practice on many manual transmissions and even autos, on manuals it makes it damn near impossible to engage reverse while moving forward.
    Here is a picture, the reverse gear (not the reverse idler) is straight cut while the forward gears are helical.
    otis24 likes this.
  3. Mar 30, 2015 at 5:19 PM
    gearcruncher
    Canadain bumper technician
    Is your truck a 4x4 or 2 wheel drive ?
  4. Apr 1, 2015 at 6:14 AM
    Edie011
    Central ohio
    4wd. It's a pretty bad grinding sound. The 1998 5 speed tacoma I had didn't grind this bad
  5. Apr 1, 2015 at 6:47 AM
    Edie011
    Central ohio
    Yes I understand the extra noise related to most reverse gears, this is actually a grinding noise
  6. Apr 1, 2015 at 6:51 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    You need to get the truck on a lift with someone in the cab to put it in gear while you or someone searches for the grinding sound. I would stop driving it immediately until you figure this out. A $100 repair could turn into a $1000+ repair very quickly.
  7. Apr 1, 2015 at 7:07 AM
    Edie011
    Central ohio
    It shifts through the gears flawlessly. I agree it needs to be addressed soon though I was just wondering if someone had any insight as to what might be causing this
  8. Oct 24, 2018 at 5:33 AM
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    Did you ever figure out your problem?
