Grinding noise towards right front wheel when driving slow.
Discussion in '1st Gen. Tacomas (1995-2004)' started by UberTaco, Nov 21, 2017.
  1. Nov 21, 2017 at 1:05 PM
    UberTaco
    UberTaco [OP] Member
    Zaq
    2001 White Tacoma
    Green led bulbs count?
    I have an 01 Tacoma, and maybe withing the past week, when I dip 10mph or below I hear/feel a grinding like noise even when I'm not braking. I crawled under there, but am slightly clueless what I am looking for. Any ideas or suggestions what could be the problem. Thanks!
  2. Nov 21, 2017 at 1:37 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Possibly brake pad squealer tab thing to indicate pads are ready to be replaced? Or wheel bearing?
  3. Nov 21, 2017 at 1:46 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    metal high pitched sound prob a brake pad sticking, grinding sound more likely a wheel bearing.
  4. Nov 21, 2017 at 2:48 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Easiest thing to look at is your brake dust cover.
    It's the thin metal disk that goes between the brake rotor and the rest of the wheel/hub assembly. Those can bend pretty easily, and is an easy fix (just bend it back, lol). Maybe it's rubbing on your rotor. You should see wear marks on it if it's rubbing.
    Best to jack it up and rotate the wheel back and forth, see if you hear it still. Then take the wheel of and inspect thoroughly.
    Could be your wheel bearing going bad or brake pad pieces rubbing too, though.
    Crock112 likes this.
  5. Nov 22, 2017 at 2:10 AM
    UberTaco
    Zaq
    2001 White Tacoma
    Sounds more like wheel bearing going bad unfortunately. I'll do some internet digging and see if I can find some "how to do". Thanks everyone.
    wilcam47 likes this.
  6. Nov 22, 2017 at 3:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    UberTaco[QUOTED][OP] likes this.
  7. Dec 15, 2017 at 8:15 PM
    coachk13
    coachk13 Member
    Tim
    New Orleans, LA
    2007 Access Cab 4x4 V6
    I'm thinking I might have the same issue. How can I differentiate between "brake pad" noise and "wheel bearing" noise? The only wheel bearing issues I've had were on 2 different Subarus and they were a more distinctive whirring noise at high speeds. My experience with brake pads wearing out seems to be more similar to this grinding, but it only makes the grinding noise at around 20 mph and no other times and not when I'm braking.
  8. Dec 15, 2017 at 8:46 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    first things first. inspect the brake. make sure they're not metal to metal. [​IMG]
    wilcam47 and coachk13 like this.
  9. Dec 15, 2017 at 8:52 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :eek:
  10. Dec 16, 2017 at 4:17 AM
    Tbimm
    Tbimm Well-Known Member
    Tom
    Belle Chasse La.
    2000 Tacoma Prerunner
    Bilstein 5100's front and back. OME 880 front coils. General HD rear springs. Fuel 16x8 Enduro rims. Dick Cepek Extreme Country 285/75/16's Some kind of headers. K&N cold air intake.
    Meh. I've seen worse. A lot worse. LOL
  11. Dec 16, 2017 at 10:12 AM
    wilcam47
    Will
    Bourbon state
    more likely a bearing in your case since its not when you apply brakes.
    Frito likes this.
  12. Dec 16, 2017 at 10:57 AM
    coachk13
    coachk13 Member
    Tim
    New Orleans, LA
    Well, shit.
  13. Dec 16, 2017 at 5:16 PM
    CodeSeven
    Serge.
    Coachella Valley
    My nephew had an 01 quad cab and did the front brakes on his own. Not a smart guy...... Put the brake pads UNDER the retaining pins thinking they just held the pads in the caliper and drove off..... you can imagine what happened when he called me a few weeks later wondering why he cant stop his truck anymore.......
  14. Dec 17, 2017 at 5:25 AM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    Get that wheel up off the ground and spin it... you'll know more. I have had the dust cover chaffing and just bend it back like jbrandt mentioned. Sound does drive you crazy though.
    TacomaInTx likes this.
  15. Dec 19, 2017 at 4:45 PM
    coachk13
    coachk13 Member
    Tim
    New Orleans, LA
    Definitely the wheel bearing. I did the push/pull test and it had some play and when I turned the wheel with it jacked up, I could hear the grinding. Took the wheel off and turned the rotor and got the same feedback. Also noticed a ton of rust on the brake calipers. What can I do to make sure I don't screw anything up because of the rust when removing all of it?
  16. Dec 25, 2017 at 6:55 PM
    wilcam47
    Will
    Bourbon state
    If the bolts and parts look really bad you might want to replace them as well. But if its just surface rust it shouldnt be a problem taking it apart. You'll know if its bad if you break stuff taking it apart.
    coachk13[QUOTED] likes this.
  17. Dec 25, 2017 at 7:01 PM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    It's a "while you're in there" situation. If you're disassembling that much to get to the bearing do the brakes at the same time. Although you should do brakes on both sides at the time. I recommend do both bearings as well since if one is gone the other may not be far behind. But, I tend to go over the top with maintenance so don't take my word as law.
    coachk13 likes this.
