Grinding noise when turning wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hesher Lord, Jul 12, 2019.
  1. Jul 12, 2019 at 4:42 PM
    Hesher Lord
    Hesher Lord [OP] Well-Known Member
    Biloxi, MS
    I bought an '09 Tacoma yesterday and they told me at the dealership they needed to replace one of the bearings and that they would have me bring it to them this coming Monday to do the work.
    The truck has a high-pitched whine that gets worse with acceleration that I'm assuming is the bearing. Forgive my stupidity in this matter, but could this also be causing this loud grinding noise when I cut the wheel during a turn? It sometimes happens when going up/down my driveway as well, but is definitely more noticeable during a hard turn. I thought it may be tire rubbing but I had someone watch me turn and they confirmed it is not. Any help is appreciated.
  2. Jul 12, 2019 at 4:46 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Sounds like a cv joint.... 4x4?
  3. Jul 12, 2019 at 4:50 PM
    Hesher Lord
    Biloxi, MS
    No sir, just a 2WD. I figured it may have to do with the bearing since it's only happening on one side (right turns).
  4. Jul 12, 2019 at 4:52 PM
    Gixerkiller
    Dennis
    Taylor, TX
    Ok, check the ball joints also, if the grinding is under braking, you may have shit the pads or a corroded rotor.
