GRINDING NOISE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by odinsbro15, Apr 4, 2016.
  1. Apr 4, 2016 at 11:26 AM
    odinsbro15
    odinsbro15 [OP] Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    i get a very quick grinding noise when i hit a road bump too fast and when i go off roading and turn... it sounds like a metal gear grinding out and its very rare i hear it. anyone else hear it. sounds like its coming from the engine bay
    Eric
    specter208 likes this.
  2. Apr 4, 2016 at 12:12 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Check your u-joints for grease?? A lot of trucks were shipped out without lube in the u-joints. You can of course take the truck to the dealer and ask to have them check the u-joints AND lube them. My dealer ignored me when I asked them to change my oil and do a lube for the first 5K service. So be aware of that issue... I have talked with Toyota Care to get this squared up so you may have better luck with your local dealer than I did. It could of course be something else as well.
    I'd have it looked at and tell them about the lube deal and check for something else - could also be ture rub if you changed to larger tires.
  3. Apr 4, 2016 at 4:58 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Could be your trac control stopping a rear tire from spinning.... Thy this.... go to the same corner and try to replicate it.. if you can... then try it with Trac off and anti skid off... bet that's the culprit.... If so... that's supposed to do that.. no worries.
    odinsbro15[OP] likes this.
  4. Apr 5, 2016 at 6:42 AM
    odinsbro15
    Eric
    LOS ANGELES CA
    lmao that totally "slipped" my mind :rofl:. im almost positive thats it now! thank you
