Grinding noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma09, Jun 27, 2010.
  1. Jun 27, 2010 at 3:52 PM
    NCTacoma09
    NCTacoma09 [OP] Stand for Nothing or Die for Something
    Andrew
    North Carolina
    Black 09 Double Cab 4x4 V6
    In about one of every ten times I start my truck I get this grinding noise. Ill get in my truck start it and it will sound fine for about 3 seconds then ill hear this grinding noise for about a second then it will sound fine again. I have no check engine lights on or any other obvious signs that I would have a problem. My truck is a 2009 and havent even had it a year yet. Any ideas as to what this may be or anyone else have a similar problem.
  2. Jun 27, 2010 at 3:58 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    It could be parts and pieces of a Ford or Chevy that your truck is grinding up. Do you often see bent up or broken yellow crosses in your drive way? :p
    Wish I could help ya diagnose it but I really have no clue. I dont suppose the dealer could take a look at it, for free... Is it under warranty?
  3. Jun 27, 2010 at 4:02 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  4. Jun 27, 2010 at 4:04 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    is it when the A/C initially kicks on for the first time after sitting?
  5. Jun 27, 2010 at 4:07 PM
    Xenuex
    Xenuex Member
    Brent
    (From WA)Stationed Camp Lejeune, NC
    1999 Tacoma
    Cound be your starter itself. I can't think of it's technical term, but theres a gear that engages to your flywheel when you turn your ignition over. And is released once you let go of your key. That could be getting power surges. Or something within your ignition system.
    It is hard to say for sure, 100% over the internet. But that's my two cents.
    Then again, like everyone else has posted, if its still under warrenty...go to the dealer.
  6. Jun 27, 2010 at 4:21 PM
    NCTacoma09
    Andrew
    North Carolina
    Everytime it has happened the A/C has been on. But sometimes it doesnt happen at all when the A/C is on.
  7. Jun 27, 2010 at 7:19 PM
    jhodge83
    SC
    17 XLT Sport
    sounds like what mine does after it's been sitting for a while. truck comes on, then the A/C kicks in and makes a loud noise for a second, then never hear it again until it has set for many hours. mine didnt start doing it until after a few wheeling trips. no issues besides that noise w/ it, so i just deal
  8. Jun 27, 2010 at 7:26 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    If my A/C is on when starting the truck, it makes a grinding sound. Like stated above.
  9. Jun 27, 2010 at 8:04 PM
    NCTacoma09
    Andrew
    North Carolina
    Well seems like a few of us are having the same problem. Can any mechanics give us any insight as to what this may be and if it is something that should be worried about. My truck is still under warranty so I might go have it looked at just to be on the safe side.
  10. Jun 27, 2010 at 8:07 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Idk, but I'm going with the "If it ain't broke, don't fix it" approach.
