Grinding/rubbing noise when turning.
Discussion in 'Performance and Tuning' started by andrew7940, Mar 11, 2014.
  1. Mar 11, 2014 at 4:29 AM
    andrew7940
    andrew7940 [OP] Well-Known Member
    Andrew
    Lousiville, KY & Charleston, WV
    06 DB CAB TRD Sport 6speed
    Kenwood DNX 573s, ICON lift kit with Dakars,
    Yesterday I was driving home from work and when I pulled into my parking spot I noticed a grinding type sound. So I backed out took it to the other end of my complex and did some tests to see if the tires might be hitting something or something was stuck. The noise stopped for awhile then I went to back into my spot and it did it again. I took it to toyota of Louisville where I had the 120k service done with both front and rear diffs also serviced in preparation for my move cross country. Since it was late the dealer tried to tell me that it wasn't making any noise and I needed to make an appointment. Thankfully a buddy was there who confirmed the noise when we backed it out. Then one of the techs also heard it when he came out. They couldn't figure out what was wrong last night so now I have to go back in today. I'm hoping it's not a wheel bearin or anything expensive since I ordered a lift kit recently that still hasn't arrived yet. Does anyone have an idea what this might be? It's an06 4x4 double cab 117k
  2. Mar 12, 2014 at 6:41 AM
    andrew7940
    Andrew
    Thanks. I took it in yesterday to the dealer and they heard the same sound. It actually started to get worse when I pulled it in. They put the truck on the lift and checked everything but found no issues they said. They changed the differential fluid for front and rear again and that seems to have done the trick. I think that they didn't do it saturday or did something incorrectly. However, the truck hasn't made the same sound since. I'll try and see if it does it later today once I drive back to my place, hopefully this fixed it although I'm still a little nervous about what it could have been.
  3. Jul 29, 2014 at 12:20 PM
    Ryan21584
    Ryan21584 New Member
    PA
    08 Toyota Tacoma TRD
    Hey Andrew, do you still have the noise?
  4. Nov 1, 2014 at 9:06 AM
    andrew7940
    Andrew
    No man. They fixed it. They forgot to put the additive in the diffs
  5. Dec 7, 2018 at 1:56 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Their should only be additives in the rear diff if its a true lsd
