Grinding/ Seizing from front end after 3" OME lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goldenstone, Sep 15, 2011.
  1. Sep 15, 2011 at 7:25 AM
    goldenstone
    goldenstone [OP] Member
    Calgary
    07 TRD Tacoma
    3" OME lift with AAL in the rear. 285/70/17 Nitto All terrains
    Hello all, I just found this forum and this is my first post. I searched around the forum and have seen similar problems, but my issue seems different. I installed a 3 " OME lift with a diff drop almost 3 months ago on my 07 TRD. In the last week when I am turning left, I have noticed a grinding and kind of clanking noise coming from the drivers side front end, sometimes the noise occurs slightly while slowing down too. I have also noticed that the steering wheel jerks to the right when slowing down.
    After reading a few posts I decided to try and put it into 4WD to see if this made the sound dissapear. It makes the sound way worse, and almost seizes the front end. In 4WD I could not turn at all and it seemed like the front drivers side was locking up. Any ideas what this could be, I am calling the shop today that installed the lift, but would like some ideas of what could be the issue.
    Thanks in advance
  2. Sep 15, 2011 at 7:28 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Sounds like the wheel bearing is FUBAR.
  3. Sep 15, 2011 at 7:30 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Bingo
  4. Sep 15, 2011 at 7:32 AM
    goldenstone
    Calgary
    07 TRD Tacoma
    Wow, I am impressed with the fast responses. Thanks alot. If it is the wheel bearing it makes sense that the sound worsens with 4WD engaged? Also, could this be due to improper install of the lift kit? SOrry for my ignorance, I am not too mechanically inclined
  5. Sep 15, 2011 at 7:34 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Yes (to the 4wd?), and no (to the fault of the lift).
  6. Sep 15, 2011 at 7:34 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Nope. The wheel bearings on these suck balls. They're pretty much disposable. Honestly.
    Ben - You and your first gen can shut the hell up right now.
    You can do it yourself and save a lot of cash. There's a tutorial on here somewhere about doing it.
    Where in Calgary are you located? I'm up in Coventry Hills.
  7. Sep 15, 2011 at 7:36 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, the lift has nothing to do with it. It's coincidental.
  8. Sep 15, 2011 at 7:38 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  9. Sep 15, 2011 at 7:38 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  10. Sep 15, 2011 at 7:43 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
  11. Sep 15, 2011 at 7:44 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  12. Sep 15, 2011 at 7:45 AM
    goldenstone
    Calgary
    07 TRD Tacoma
    Thanks again guys, who needs a mechanic when you can get advice this fast! Krazie, I'm down in the dirty south by Spruce Meadows. I'll look at the link and see if I think I can do it myself. Do you think it would be warranty? I bought the extended warranty when I bought out my least in March, or will the lift kit void warranty?
  13. Sep 15, 2011 at 7:46 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm not yet convinced it's wheel bearing, but doing more tests is indicated.
    Jack up the front end a couple inches (set the parking brake first!) and grasp the top and bottom of the tire and try to wobble it.
    Do the same thing front and back.
    Wobble indicates bearings.
    Also, just spin the wheel and listen. You want a quiet, smooth spin, though you may hear a little brake caliper drag. But a clunking, clicking, ticking spin indicates wheel bearings.
  14. Sep 15, 2011 at 7:53 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Right on. I used to live in Cranston, so I'm guessing you're probably closer to Evergreen or Somerset.
    And it all depends on which location you take it too. I'd recommend Heninger Toyota. The local club goes there, so they're used to working on modified trucks. Honestly though, there's a chance they'll tell you to go pound sand due to the lift. But if anywhere has a chance it's Heninger.
  15. Sep 15, 2011 at 7:53 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    could possibly be a bad CV shaft/joint
  16. Sep 15, 2011 at 8:22 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    These things are notoriously difficult to pin down without seeing the truck, and can be difficult even if you have the truck in hand. So while I acknowledge the expertise of some of the posters on this forum - so far no one has given you this caveat.
    You say it sounds like driver side - but then when you brake, it pulls passenger. Sounds are very difficult to pinpoint directionally. The problem may well be passenger side.
    Have you put the truck in 4wd on pavement before? As soon as you try to turn, the tires bind up against the pavement (tacomas have no center differential.) I'm not sure exactly what you mean by "almost seizes the front end" but you shouldn't be trying to learn anything by going into 4WD while on pavement except to detect a change in rolling sounds when going completely straight.
    Basically, I'm strongly recommending you have a mechanic look at it do diagnosis, rather than do-it-yourself start replacing parts based on internet diagnosis. If you get a confident diagnosis from someone you reasonably trust, and then decide then to take on a DIY repair that's another thing. At least then you can follow the steps in a shop manual to do a remove & replace with fair confidence that what you're replacing will actually _solve_ the problem.
  17. Sep 15, 2011 at 9:20 AM
    goldenstone
    Calgary
    07 TRD Tacoma
    I put the truck into 4wd while rolling slowly straight forward, I instantly started to hear the grinding/binding noise, and the truck slowed right down and it felt as if it took alot more gas to get the truck to move forward. On a slight turn of the wheel the noise became much louder and basically stopped the truck.
  18. Sep 15, 2011 at 9:22 AM
    goldenstone
    Calgary
    07 TRD Tacoma
    I was thinking it could be a CV issue, as I have read some CV threads and some of the symptoms sounds similar.
  19. Sep 15, 2011 at 11:38 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Turning the wheel while in 4WD on hard ground will stop your truck and make it so it takes a lot of gas to move because you're causing drive line bind and you'll essentially blow up your transfer case.
    Bad goldenstone. Bad! *Sprays with water*
  20. Sep 15, 2011 at 3:29 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If the boots aren't torn I wouldn't expect the CV to be bad. That's a rarity. It's more common for the bearings to fail.
