Grinding sound after 6 in lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thatcarter85, Feb 27, 2023.
  1. Feb 27, 2023 at 7:11 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Once while I was out and about the shielding on the side of the gas tank was somehow bent over far enough to rub against the drive shaft. Easy enough fix with some duct tape.
    5465 and Steves104x4 like this.
  2. Feb 28, 2023 at 5:52 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    Think that"s how the internet comes through the house
    jackn7, 3JOH22A, whatstcp and 3 others like this.
  3. Feb 28, 2023 at 6:20 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    I though that was a rooter?
    jackn7, whatstcp, Chew and 1 other person like this.
  4. Feb 28, 2023 at 7:09 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    no, no, that's a r-o-u-n-d-e-r.
  5. Feb 28, 2023 at 7:15 AM
    Ryan's Taco
    They are square not r-o-u-n-d-e-r
    jackn7 and ToyoTaco25 like this.
  6. Feb 28, 2023 at 7:25 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Could be pinched brake hose, incorrectly assembled pads, missing/bent pad retainer pin, incorrectly installed anti-rattle clips, pad squealer clip bent too far and touching prematurely, incorrectly manufactured spindles putting the caliper off center relative to the rotor...
    jackn7 and bulalo like this.
  7. Feb 28, 2023 at 8:51 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    with the lack of info and pics,,,, this is the best advice.
    Guess away!
  8. Feb 28, 2023 at 9:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    @Thatcarter85 just take it to the shop that installed the lift and ask them to rectify it. Go on a ridealong with the mechanic and point out the grinding sound when it happens.
    hilighter and Ryan's Taco like this.
  9. Feb 28, 2023 at 9:37 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I like this approach. "Make it happen"
  10. Feb 28, 2023 at 10:59 AM
    Ryan's Taco
  11. Feb 28, 2023 at 2:16 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Nice router
  12. Feb 28, 2023 at 2:19 PM
    Ryan's Taco
    It is a pretty nice piece of equipment.
    ToyoTaco25 likes this.
  13. Feb 28, 2023 at 4:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Ask for that next time at your dentist
    henryp and ToyoTaco25[QUOTED] like this.
  14. Feb 28, 2023 at 4:15 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    How much lift? Any rubbing?
    Probably not since it's not plugged in.
  15. Feb 28, 2023 at 4:17 PM
    #35
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    :eek:
    Hope you find a fix, OP.
    Chew likes this.
  16. Feb 28, 2023 at 4:22 PM
    #36
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    No, I'm pretty sure that's a rooty tooty fresh and frooty.
  17. Feb 28, 2023 at 4:24 PM
    #37
    Chairmanmeow66
    Chairmanmeow66 Well-Known Member
    2020 Tacoma TRD off road
    Get a similar sound with a 6in lift at around 5-10mph :confused::confused:
  18. Feb 28, 2023 at 5:10 PM
    #38
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    The typical diagnostic experiment would be to enable 4WD and see if the sound/vibration goes away.
  19. Feb 28, 2023 at 5:34 PM
    #39
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    LOLOLOL yeah no shit. 6 inches is too bookoo but to each their own.
  20. Feb 28, 2023 at 5:53 PM
    #40
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Jack both front wheels off the ground, with the truck in 2WD. You should be able to turn the wheels by hand and check for tire rubbing and/or grinding sounds in the front drivetrain and tire/wheel set up. You can run the engine and steer the wheels left and right and check again.
    If you find nothing, turn the engine off, block the front wheels, and Jack the rear end up and repeat. (Keep in mind your parking brake and transmission brake don’t work when you jack the rear end up).
    My guess: The shop did not properly loosen off your parking brake cable slack adjuster (inside your center console) to account for the lift and you are dragging a rear brake shoe. When you pull the E-brake handle there should be 7 clicks. If you have like 2 or three clicks you may be dragging a shoe in the rear. This is a common mistake made by shops and happened to me.
    smikski likes this.
